Comp XER 232/234 .595/.598 112LSA?
Does anyone know anything about this cam? And is anyone running it? If so what kinda numbers are you getting and what kinda power band does it have?
Originally Posted by luv2spd
I would think you'd be just fine with your stall.
It should never see 7200 rpm's. XE-R lobes fall off pretty hard after peak, and that 232 intake lobe should peak around 64-6500 rpm's depending on advance and LSA. As for anyone having the cam and diffrent numbers, all you have to do is look at the graphs for cams like it. The X2, FM13, or any other cam on a stiff lobe with around the same duration will have a similar graph.
