which head gasket to go with for AFR
Old 01-26-2005, 10:42 PM
WS6FirebirdTA00's Avatar
Default which head gasket to go with for AFR
ok, i tried to search and im having a hard time with this one. i dont know which head gasket to go with. i dont wanna get into any P-V problems and i know with factory gasket, and afrs with the f13 cam i will be ok. i keep hearing about the gm mls but i have no idea what it is. so what would be a good one to use? 10.28 cmopression with factory gaskets. and what would the part number be of the ones you recommend?
Old 01-27-2005, 05:09 AM
LS1TECH Sponsor
mikey's Avatar
Which AFR Head? Use a 2002+ GM factory gasket (MLS = multi layer steel) on the 205's. Use a Cometic 4.130 x 0.054" with the 225's.
Old 01-27-2005, 05:14 AM
goober35's Avatar
I have to go with mikey on this one.
Old 01-27-2005, 05:42 AM
Viper's Avatar
I went with a Cometic at .045". My pistons are .007 out of the hole.
Old 01-27-2005, 08:02 AM
VortechC5's Avatar
I used the stock GM 2002 with mine and everything is fine so far with boost.
Old 01-27-2005, 08:41 AM
what is the part number for that gm gasket? im getting multiple numbers when i search for it and i want to get the right one. what is the thickness on those gaskets?
o yeah it is the 205 head
Old 01-27-2005, 08:54 AM
NHRATA01's Avatar
Yeah, thats what I'm trying to figure out in my topic a few down. The p/n of the ones I got from Thunder are different then the p/n I see everyone post on here.
Old 01-27-2005, 09:07 AM
might have to give SDPC a call, unless someone on here knows for sure
Old 01-27-2005, 07:27 PM
VortechC5's Avatar
This is what I used:
GM PART # 12498544
GM LIST: $30.99
OUR PRICE: $21.69
DESCRIPTION: GSKT KIT Cylinder Head Gasket Kit "2002-2004" This gasket kit includes two head gaskets for 2002 through 2004 LS1 Camaro and Corvette.
Old 01-27-2005, 08:05 PM
damn thats cheap too, cool. is that from gmparts ?
Old 01-27-2005, 08:07 PM
VortechC5's Avatar
Yes it is.
Old 08-27-2005, 11:23 AM
2000Firehawk's Avatar
What head gasket to use with 1998 LS1 w/AFR 205cc.
I think 1998 has some sort of 'notch' ??
Old 08-27-2005, 01:42 PM
not sure but i would go with some cosmic gaskets to get hte right quench, after finding out some more info i dont think mls was the best choice
Old 08-27-2005, 05:32 PM
smask04C5's Avatar
I used a set of .040 cometics with ARP studs on my 62cc AFR 205's. No issues, great gaskets and reusable
Old 08-27-2005, 06:01 PM
where did you get them from?
Old 08-28-2005, 05:35 AM
smask04C5's Avatar
ordered direct through cometic
