Is this normal? (Gunk on cylinder walls)
Hello. I'm in the process of cleaning my early 2001 LS1, supposedly with 20K miles on it. I cleaned the piston tops, but when I rotate the engine a sludge gets left behind. From what i can tell, it starts (gets deposited) at the top of the piston travel and then some gets dragged downward.
Is this normal? When I take out and clean the pistons will this stuff go away or is it a pre-cursor of future problems?
Attached are pictures.
Thanks
Ben
Thanks
Ben
No I don't think it's rust. Looks like Carbon build up where the top of the "top Ring" is. You should try to get all of it out. Get a hard tooth brush (the Extra firm type of tooth brush) and some top end cleaner. Get a rag to dampen the area where it is at. Let it sit for a little bit and then (with a rag under it) Loosen it up with the tooth brush. Then wipe it away. Should be able to get most of it like this.
As far as the stuff already in the Cyclinder, just poor a little in each. YOU WILL HAVE TO DRAIN THE OIL PAN. Carb cleaner should finish it off and will dry clean. Basically you are flushing out all the carbon build up on the compression ring and the quench area of the piston.
Thanks for the replies. You learn something new everytime. I've never cleaned pistons on an engine so I definitely think it is the WD-40/residue buildup that was being left on the walls. I guess it filled up the ring lands and got squished out when the piston changed direction as the oil control ring is too low to clean that. Excellent, thanks again.
The engine is coming completely apart so I'll pay special attention to cleaning the ring land area when the pistons are out.
Thanks
Ben
Thanks
Ben
