gasket difference?
Old 01-30-2005, 12:38 AM
Blue02Ws6's Avatar
Default gasket difference?
What is the difference in gasket compressed thickness between the graphite and metal ls6 gasket? I have some .040 shaved heads and and really wondering if I am getting too close to my pistons with my 227/227 .564 .564 lift cam it is on a 114lsa. I know it will be pretty close but will it be too close?
Old 01-30-2005, 02:33 PM
Blue02Ws6's Avatar
I know someone has to know this....
Old 01-30-2005, 04:58 PM
Beast96Z's Avatar
The graphites are .054 and the GM MLS are .064. Not sure of a metal LS-6 gasket??? Do you have a part number?
Old 01-30-2005, 05:14 PM
smask04C5's Avatar
check p/v clearance and if you have room, use mr gasket 5713G and 5714G, they are .042 compressed
Old 01-30-2005, 06:04 PM
Blue02Ws6's Avatar
I already have these mls gaskets from gm, I just got the part# off this website somewhere....didn't know there were this many types of gaskets and thicknesses. I am just worried about my p/v clearence. I would like to run as high of a comp ratio as I could though.
Old 01-30-2005, 06:22 PM
smask04C5's Avatar
use checker springs and degree cam, just completed a h/c install on my 04 vette and with 2.055 intakes, had .095 clearance on intakes with pistons out.007 and using mr gasket head gaskets .042 compressed. i run the crane 1.8 rocker kit, lift with boss 2 cam works out to be .590. you really should check p/v, every case is a little different, should try to keep squish between .035-.040.
Old 01-30-2005, 06:33 PM
Blue02Ws6's Avatar
Were your heads milled any?
Old 01-30-2005, 06:57 PM
smask04C5's Avatar
nope, brand new. removed steel shims from mls gm gasket to thin them out to approximate mr gasket 5713-14. boss 2 cam specs are 216 224 .551 lift but .590 with 1.8 rockers. need a minimum of .080 do you have a degree wheel kit? most come with checker springs
Old 01-30-2005, 07:21 PM
Beast96Z's Avatar
You should use the gaskets you have to check clearence with. Install you a couple of check springs on 1 cylinder of your heads.(intake and exaust) Then lightly tighten them down, with gaskets in place and clay on the piston. Once they are seated, then roll the motor over. You can now remove the head and use a dial caliper to measure your clearence. If you have enough room, a ,040 or .045 gasket will be perfect depending on how far out of the hole your pistons are.
Old 01-30-2005, 07:44 PM
smask04C5's Avatar
i used my old mls gaskets with shims removed, because i was waiting for new ones to come in. slid them over studs and clayed #1 piston, installed head with checker springs, rolled over,measured and had .095 clearance
Old 01-30-2005, 08:00 PM
Blue02Ws6's Avatar
I am not a huge gearhead, I am mostly just getting into this but love to learn this stuff. I have no idea what you are talking about checker springs. I take it they are kinda really loose springs that are for mock-up purposes kinda? The gaskets I have are part# 12589226 I take it these are the mls gaskets. To tell you my engine building experience, I had never changed my oil in my car till I did my own cam swap...lol I am one of those people that could be really dangerous if not guided..... So basically just take some modeling clay and check my clearence with my setup and keep it within .040-.050 p/v? How would I simulate the right gasket compressed height without torqueing down all my bolts? I really don't want to tear up a new set of gaskets to remove the metal shims either.
Old 01-30-2005, 11:24 PM
Beast96Z's Avatar
By checker spring, I mean light weight low pressure springs. This way they don't compress the hydraulic lifter, giving you a more accurate reading. As far as gaskets go, you want to keep your "quench" between .035-.040". Quench is the area from the top of your piston at TDC to the bottom of your head deck. Most LS-1's are .007" out of the hole, so if you have a .045" thick head gasket, this gives you a .038" quench. You can check your clearence like you said. Just place some modeling clay on the piston around the area were the valves will come down. Set your gasket on, then the head tightened down till good and snug. Then place your rockers on and set them for "0" lash. Tightening them to 22 ft. lb's will compress your spring and you don't want that. Now you can roll your motor over until you see both of those intake and exaust valves make there way up and down. You probablly won't even have a mark on the exaust side. On th eintake side, you can use the "pin" end of a dial caliper to measure the thickness of the clay in the indention made. You want to keep your piston to valve clearence around .090-.100, but I've seen some run .080 and not have problems. When it comes down to it, if you have room, get a thinner gasket. Preferablly a ,045".
Old 01-31-2005, 01:13 AM
Blue02Ws6's Avatar
how much are the Mr gaskets ones? I would like to get my quench down to .035 if I could. I don't know if I will be able to though with these heads shaved .040 and my cam.
Old 01-31-2005, 02:06 AM
z-ya's Avatar
They are cheap about $20 each.
Old 01-31-2005, 08:38 AM
smask04C5's Avatar
5713G and 5714G, $20 ea.
Old 01-31-2005, 09:57 AM
Blue02Ws6's Avatar
Thanks for all the info guys. I have learned alot in this thread now, and now know I have a lot of testing ahead of me.
