CR Help
Old 02-03-2005, 12:02 PM
98Raptor's Avatar
Default CR Help
Can someone help me calculate the CR for my new engine?
This is what I got.
Hand ported 5.3 Heads with LS6 sodium filled valves (flowed 291 int and 226 ext) These have not been milled at all.
6.0 Liter stock short block. I think it is the LQ9. It has dished pistons. Again the sort block is stock.
GM metal 6.0 liter gaskets.
Not sure if you need anything else.
Old 02-03-2005, 12:11 PM
jrp
SN95 Director
jrp's Avatar
dished pistons = lq4
with that said i come up with ~10.3CR
Old 02-03-2005, 12:26 PM
Unaffliated Racing's Avatar
Yeah I came up with about 10.29....close enough...lol
Old 02-03-2005, 12:30 PM
98Raptor's Avatar
How did you guys come up with that?
Old 02-03-2005, 12:32 PM
jrp
SN95 Director
jrp's Avatar
4.00" bore
3.622" stroke
~62cc chamber
.060 gasket
4.100" gasket bore
-.008 deck height
6.6cc dish
all into a CR calculator
Old 02-03-2005, 04:21 PM
98Raptor's Avatar
Originally posted by jrp
-.008 deck height
6.6cc dish
Where did you get this info?
Old 02-03-2005, 04:32 PM
jrp
SN95 Director
jrp's Avatar
deck height is gm spec and i learned the dish volume from the truck guys. once thought of swapping an 6.0 into my car myself
Old 02-03-2005, 04:45 PM
98Raptor's Avatar
Enter Piston Deck Clearance Negative If ABOVE Deck (Use '-') : -.008
Is this correct then? Just wanted to make sure it really is ABOVE the Deck.
Sorry if I sound dumb on this issue. First time for everything.
Old 02-03-2005, 04:48 PM
jrp
SN95 Director
jrp's Avatar
yes, ls1 pistons are above the deck. gm lists -.008 but it can range from -.002 to .010 out the hole
