Is there a freeze plug that is behind the timing cover that causes lost oil pressure?
Old 04-24-2003, 05:15 PM
C4VetteLS1's Avatar
Default Is there a freeze plug that is behind the timing cover that causes lost oil pressure?
A friend of mine just got his motor back from machine shop, all new shortblock with forged pistons. He starts the motor and it runs 20 seconds and never got oil pressure. Pulled it apart, found a freeze plug missing behind oilpump/timing chain area. Put it in, had full oil pressure instantly. Why would this freeze plug be missing from machine shop? he spun a rod bearing 100 miles later, and machine shop refused to pay for it........
Old 04-24-2003, 06:03 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
Default Re: Is there a freeze plug that is behind the timing cover that causes lost oil pressure?
Was it a new block?
I don't think new blocks have the freeze plugs in them.
Yes there is a freeze plug where you are describing and I have heard of that happening before.
