Cam swap oil question
Old 02-06-2005, 11:23 AM
black_knight's Avatar
Default Cam swap oil question
So I've read a few install guides for cam swaps, and I get the impression that you change the oil with the swap (of course) and then again after a hundred miles or so.
...I also get the impression that most people here use ~$50 worth of synthetic oils for every oil change. (I know I do) Those who have swapped cams, did you just bite the bullet and pay $100 for oil changes? What is the standard operating procedure here?
Old 02-06-2005, 11:58 AM
smask04C5's Avatar
i just completed a h/c swap on my 04 C5 A4 with pp ls6 style heads, 2.055 intakes, ati damper, crane billet dual chain kit, 1.8 crane rocker and spring kit, ti retainers, dynatech ss header kit, magnaflow ss exhaust, tuned with VHP tuner. i had about 2900 miles on the car, 900 on Mobil 1 10w-30, changed when I put about 50 miles on the swap. used euro Mobil 0w-40, did not like results, changed back to 10w-30 and put used only 10 miles euro oil in my son's 180,000 mile pontiac grand prix. recommend you do the install, run it for a hundred miles or more, then change it.
Old 02-06-2005, 11:59 AM
fast98's Avatar
i only had 500 miles on my synthetic so i just left it in there, i dont see why people would change it twice. no coolant gets in the oil and if your clean u shouldn't have any problems. normally people will change the oil after cam break in on a flat-tappet cam. i see no need to on a roller cam. jmo
Old 02-06-2005, 12:05 PM
King of Pigskin Knowledge
BuckeyeROC's Avatar
I just used a decent reg oil for the first 100 miles or so and then went back to Mobil 1.
Old 02-06-2005, 01:54 PM
I'm thinking that I will change the oil after the first 100 miles or so... what does everyone think of using regular for the swap and then switching back to synthetic?
Old 02-06-2005, 01:55 PM
Ah, screw it... I'm just going to get cheap synthetic for the swap and then switch back to the good stuff after 100 miles. I don't want to be pennywise and wreck my car!
Old 02-06-2005, 02:08 PM
fast98's Avatar
u wont wreck your car, theres a oil filter on there for a reason
Old 02-06-2005, 03:09 PM
68birdls1's Avatar
well why not take the extra precautions and change the oil after 100 miles?!? i mean do what some others have said and put some cheap ole dyno oil in there, drive it a bit then go back to your regular stuff!
Old 02-06-2005, 10:33 PM
fast98's Avatar
its all about opinions, to me its a waste of money and time, to someone else its gunna save there engine (in there own lil world). i was just letting him know that the majority isn't always right. example: evryone says change your oil at 3k miles.........even with synthetic. truth is u can go much further but what the people are sold the people will believe.
Old 02-07-2005, 01:54 PM
BriancWS6's Avatar
I didn't have alot of miles on my oil when I did my swap on my pewter car, so I did the swap, drove it for a few weeks (weekend car only) then changed it before I headed to the dyno for the tuning. IMHO it's better to NOT change the oil during the swap, cause it will have oil pressure immediately when you start it, unlike if you had drained the oil and installed a new filter. To each his own, but that's my outlook on it.
Old 02-07-2005, 02:08 PM
777's Avatar
most people change the oil pumps...unless it is 01-02..seeing that he has a 99 he will probably upgrade and if he doesn't he should have...so you need to change the oil then...however...i'd just use cheap stuff during the change/break in period...then switch back after 100 miles....better safe than sorry
Old 02-07-2005, 02:25 PM
Yes I will be changing the oil pump, so I will have to change the oil then. And I will be changing it again in 100 miles or so. The question at hand is: is there going to be a problem going from synthetic (current) to non-synthetic (after swap) and then back to synthetic (within 100 miles)?
Old 02-07-2005, 02:52 PM
Krab's Avatar
I doubt there will be any negative side affects of running the dino oil for the break-in period, then switching back to the synthetic. I did this, and haven't had any problems in the last 15K miles or so. I just used Castrol 10w30 oil, and then switched back to the german made castrol.
Old 02-07-2005, 02:53 PM
777's Avatar
i can't see how dino oil will mess it up...some people use that all the time
Old 02-07-2005, 03:24 PM
1999T/A's Avatar
Not a damn thing wrong with cheap dino oil to break in new engine components . Jeff Creech @ CAM recommended me to use dino oil in my new motor until the break in period was over . I have always done this to Gen 1 SBCs and now will be doing this to my LS1s . No reason to fork over the big bucks just to drain it out in 100 miles .
Old 02-07-2005, 03:28 PM
SSCamaro99_3's Avatar
When my cam was changed (oil pump was changed as well) I bought some Exxon Superflo ($1.09 per quart), and a cheap filter. That oil was run for a couple of heat cycles then Mobil 1 and a new filter went on, and it has been just fine.
Old 02-07-2005, 03:34 PM
Okay, cool. I just figured maybe that dino oil and synthetic might sludge up if they mixed or something... (well, not "mixed," really, but there will be residue...)
Old 02-07-2005, 04:54 PM
01_SuperSlow's Avatar
Break in with dino oil and then put the synthetic back in. It'll be just fine
Old 02-07-2005, 07:00 PM
Phil'sC5vette's Avatar
How much oil drips out of the car during a cam change when the oil pump is replaced along with the cam? any, none, 1/2 a quart.
Old 02-07-2005, 08:25 PM
fast98's Avatar
very little if any, when u lower the pan u will loose some though
