GM and AFR CNC head pictures
Old 02-11-2005, 06:11 PM
Flareside's Avatar
Default GM and AFR CNC head pictures
They're not really useful, but I thought you guys might like to see a few pictures of the GM CNC LS6 and AFR heads side by side. I got the GM heads from a friend for cheap, and I had planned to install them, but then read too many posts from Tony M and decided to go with the AFRs instead. Got the AFRs from SDPC today. Now if I can just decide between the GT2-3 or AFR 220/224 cam, I'll be ready to put the damn car back together!
The AFRs are at least 25% heavier, maybe more.
GM on left, AFR on right
AFR intake port
GM intake port
GM intake port
AFR exhaust port
GM Exhaust port
GM chambers 60cc
AFR chambers milled to 62cc
Attached Thumbnails GM and AFR CNC head pictures-2.jpg   GM and AFR CNC head pictures-gmcncchamber.jpg   GM and AFR CNC head pictures-afrchamber.jpg   GM and AFR CNC head pictures-3.jpg   GM and AFR CNC head pictures-4.jpg
Old 02-11-2005, 06:27 PM
70T/A400's Avatar
In your opinion, what are the physical differences between the heads? Thanks,
Glen
Bill's 02 Z-28 SS's Avatar
Hi
Great pictures - they are very interesting. The one thing that I noticed is the ARF chambers is a lot smoother than the GM but other then that, they look very much the same. The real test work to take a stock LS1 and try each head on the motor to see which one made the most power. I bet it would very close. Just my two cents
Bill
Old 02-11-2005, 06:32 PM
jrp
SN95 Director
jrp's Avatar
i love posts like this, its interesting to see direct side by side comparisons . those are the GMMP LS6 heads right?
Old 02-11-2005, 06:42 PM
Flareside's Avatar
Glen
Visually, they look very similar, but when you lift them you can really feel a difference. The AFRs are at least 25% heavier/thicker. I'll try to weigh them later tonight.
The GM heads are actually the GMPP LS6 CNC heads, part number 88958622.
The chamber shapes surprised me, I didn't think there would be so much difference. I wonder what the technical reason for the change from a heart shape to a figure 8 is? The bump at the plug is also completely different.
Old 02-11-2005, 06:54 PM
Flareside's Avatar
Originally Posted by Bill's 02 Z-28 SS
Hi
Bill
The flow number make me believe that dyno numbers would be similar, but I'm really hoping that the smaller AFR port provides better throttle response that the dyno would never detect. We'll see. I measured an intake port in each head, the AFR was 206cc, the GM was 241. Big difference.
Old 02-11-2005, 06:59 PM
Ed Curtis's Avatar
Cool
Those AFR heads should make the car rocket with their smaller, efficient ports! Quality air and great velocity.
Good luck!
Ed
Old 02-11-2005, 07:11 PM
Wnts2Go10O's Avatar
its a way to make it more like the hemispherical heads ie, increaes efficiency. the 8 would, i think, provide a better combustion by placeing the sparkplug nearer to the center. the figure 8 is the way to do it. the extra weight could be mostly the thick deck. hell they should make chevy hemi heads for these motors
Old 02-11-2005, 07:18 PM
Squintz Palladoris's Avatar
Better Quench with the AFR combustion chamber.
Old 02-11-2005, 07:28 PM
vettenuts's Avatar
Hard to tell from the photo's, any feeling for aftermarket rockers. Looks like the AFR would not need any additional work to use them.
Old 02-11-2005, 08:35 PM
Ragtop 99's Avatar
Is it the angle of the photos or did AFR raise the floor of the intake port?
Old 02-11-2005, 09:26 PM
JohnnyStorm's Avatar
Great Pictures! Exactly what I wanted to see. I've PM'ed you
Old 02-11-2005, 09:40 PM
DavidNJ's Avatar
Ditto
Old 02-11-2005, 09:59 PM
Flareside's Avatar
That's no camera angle, that's why I spent $2200!
I'll try to get a better set of pictures of the intake ports.
Old 02-11-2005, 10:12 PM
Flareside's Avatar
I weighed the assembled heads:
GM CNC: 22.8 lb
AFR: 27.8 lb
LS1: 24 lb
GM
AFR
GM
AFR
The AFR intake ports are way smaller than the CNC LS6 ports. You can hardly even see the valves in the AFR ports.
Old 02-11-2005, 10:18 PM
01_SuperSlow's Avatar
Good post. Thanks for sharing
Old 02-11-2005, 10:30 PM
Bo White's Avatar
Some people call the shape a peanut shaped combustion chamber- it is a better design because of the dual quench that it has to direct the air/fuel mixture into the center of the cylinder for a more effiecient burn, like a fast burn head.
Old 02-13-2005, 12:18 AM
z-ya's Avatar
Afr intake port floors are raised .300 hence the better short turn radius.
Old 02-13-2005, 06:55 AM
Sport Side's Avatar
Thumbs up
Very interesting comparison.
Thanks.
Old 02-13-2005, 07:59 AM
LSonederfull's Avatar
Thumbs up
Excellent pics. very helpful and useful!
My observations are GM port has floor carved out heavily, and since its milled on deck heavily that is reason it appears AFR is much taller. Prolly not much difference as cast. Taller shortside shows more efficient design of AFR.
Dual quench design of chamber helps to seperate exhaust and intake gasses during overlap and this speeds up burn time. Thanks for great pics!
Does Afr intake valve appear canted to anyone else? It sure does to me.
