How much
Old 02-11-2005, 09:13 PM
CRZYPWR's Avatar
Default How much
I was wondering ..if You guys have any idea..
How much would machine shop charge for porting stock heads to stage 2 size and putting them back together. On avarage...
Anyone ?
Thanks
Old 02-11-2005, 09:43 PM
Blue02Ws6's Avatar
If you want a stage 2 port job, bigger valves, valve job, seals, and reassembly it will prob run about the same as buying a set of heads say from patriot which would be better since they have tested theirs and have good results. Just from what I have found arround my area this is some of the prices
valves $220
seals $20
valve job $175
Port work $400
Springs $200
$1015
That is is taking your heads off and being down until the machince shop gets them back to you and I even forgot about milling them and assembly too. For a little more money you can have a reputable sponsor do them for you and know what you are getting.
Old 02-11-2005, 09:49 PM
CRZYPWR's Avatar
Got it.
thanks a lot man
Old 02-11-2005, 09:54 PM
Blue02Ws6's Avatar
If you are worrying about keeping it cheap just look for some used heads here on the board that are from a known porter and you can save some money and still get a great set of heads, might take a while to find what you want used but I can bet if you check enough there will be a thread with what you want at a good deal.
