Mahle pistons
Mahle pistons
I hauled the block, crank, new H beam rods, and new Mahle pistons off to the machinist. After checking it out, he complained that the pistons were unmatched by a total of 5 grams. This surprised me as the Mahle pistons were touted as one of the best. OTOH, I have been out of the game so long that I don't remember how significant 5 grams is. Comments?
Originally Posted by 66deuce
i thought Mahle was the OEM supplier for the ls1 pistons?5 grams does seem like a lot,but i'm not an expert.who's doing your machine work?anybody around town here?
C&P in Fort Wayne is doing the work. I looked around and they seemed to be the most clueful of the places I talked to. One place said "what is a honing plate?"
Originally Posted by PREDATOR-Z
Well, the LS1 is internally balanced after shortblock moc assembly. So unequal piston weight can have negative effects on that and harmonics.
LS1TECH Sponsor
5 grams
Five grams is a bit much to machine off the heavy pistons to get them to the weight of the lightest one. There is not a lot of "extra" material to machine. I would send the pistons back and get another set.
Steve
Steve
__________________
Steve Demirjian
Race Engine Development
Oceanside, Ca.
760-630-0450
web: www.raceenginedevelopment.com/
e-mail: race-engine-development@***.net
Steve Demirjian
Oceanside, Ca.
760-630-0450
I agree 5 grams is high but arent Mahle pistons inexpensive? I would weigh pins and weight match them to pistons alleviating weight mis match as much as possible, than i would lighten heavy pistons as much as safely possible.
If still off you can lighten pins by grinding inside pin and re polish grind marks to finilize weight match.
Mahle
I just sent my rotating assembly to have it balanced. A new set of Mahle pistons,pins and rings were included with the crank, rods and harmonic balancer. The pistons, pins and rings were within 1 gram + or minus for each cylinder. The weight of a stock GM PISTON is 434 grams. The weight of a Forged Mahle piston is 382 grams. That is a weight savings of almost 15 ozs. of rotating mass in 8 pistons. This is the same manufacture for the LS1-LS6-LS7-AND THE C5R. If it is good enough for them, it should be good enough for me. It is not always the price but the quality. This time the price is in favor of the customer.
JIM
JIM
JIM
JIM
[QUOTE=c5jim]I just sent my rotating assembly to have it balanced. A new set of Mahle pistons,pins and rings were included with the crank, rods and harmonic balancer. The pistons, pins and rings were within 1 gram + or minus for each cylinder. The weight of a stock GM PISTON is 434 grams. The weight of a Forged Mahle piston is 382 grams. That is a weight savings of almost 15 ozs. of rotating mass in 8 pistons. This is the same manufacture for the LS1-LS6-LS7-AND THE C5R. If it is good enough for them, it should be good enough for me. It is not always the price but the quality. This time the price is in favor of the customer.
JIM
I thik nk you did the rigth thing.Just send the complete anssambly to be balance!!!
JIM
JIM
JIM
