Will the F11 be too big for an M6, 3.42, & stock weight?
Sorry for "what's the best cam for me" question, but I've read countless posts and I'm still having a hard time deciding. So thanks for the patience!
The car will be driven mostly on the street, but it is not a daily driver. It will see the track at most twice a year. I do not plan on installing a rearend and/or steeper gears for sometime. And I don't want to spin the engine too high (probably shift around 6300 or 6400 rpm). My goal is to have a high 11/low 12 second car. And I plan to get all the bolt-ons.
Originally I was sold on the TR224, but after reading numerous posts I'm starting to lean towards the F11. How will the F11 perform on the street with 3.42's? If the F11 is not a good cam for my application, then what is? TR224? F5? etc.
Thanks,
Jim
Thanks,
Jim
Last summer I went through the same thing trying to pick the best cam for my 98 Z28. I didn't want to spin my motor really high and I knew I would be running the stock 3.42 rear until it breaks. I decided on the F11 on a 112 and have no regrets. My max hp was 365 at 6000 rpm and max torque was 356 at 5000 rpm. My torque was over 350 from 3200 to 5300 rpm. These numbers were with the mods in my sig, as you can see I still have the LS1 intake and stock throttlebody, stock pulley, stock thermostat and unfortunately I didn't have the cam degreed when it was installed. If I had all the bolt-ons I believe I would be in the 380 hp + range. Plus it sounds so good I could listen to it idle all day long. Like someone else mentioned, if you are not sure just give Futral a call and they can help you out.
Thanks,
Jim
Thanks,
Jim
I'll call Futral and get their opinion, but from what everyone is posting I'd say the F11 is what I'm looking for. Thanks for all the prompt responses!
i was also looking at futral cams , would the f2 or f6 make any more low end power or say win more street races than some of the bigger f11/f12
2001 ws6 mac headers w/ ory, hooker catback, SLP lid, short stick,taylor10.4`s
After reading all this, I'm happy I went with a f13. Not many people have bad things to say about FMS cams. Now I just have to get it in. What would be the optimal gear for a f11/f13?
