whining sound in cab/under dash? while driving...6 speed 99 SS
Old 02-18-2005, 10:03 PM
Kick_Ass_99SS's Avatar
Exclamation whining sound in cab/under dash? while driving...6 speed 99 SS
Hey guys-
This is what I got. I just noticed a whining coming from what sounds like under the dash as I'm driving. It is very noticeable in 1-4 gears, but 5th and 6th are not nearly as noticeable.
When I clutch to shift, the noise stops completely. If I put the car in neutral and rev, there is no whine. Only when driving in gear.
There does not seem to be any driveability symptoms or anything...so not sure whats going on.
Once again, it sounds like it is coming from the dash behind the glovebox area, or possibly even the door panel. Hard to tell sicne I am driving while it's doing it.
any ideas
sorry if this was the wrong board for this...just wanted to throw it in scein I didn;t know if the problem is with teh engine or the trans or somewehree else in teh drivetrain..
thanks guys
Old 02-18-2005, 10:23 PM
BrentB@TEA's Avatar
I have had a bad whining noise from the passenger seat every since I got married! good luck figuring out where yours is coming from
Old 02-18-2005, 11:33 PM
Cal
Cal's Avatar
Ha ha so do I!
Old 02-18-2005, 11:34 PM
Cal
Cal's Avatar
Originally Posted by Kick_Ass_99SS
Hey guys-
any ideas
thanks guys
Are you sure it's not the A.I.R. pump?
Old 02-19-2005, 12:27 AM
cueball's Avatar
Hey guys-
any ideas
thanks guys
could be the throw out bearing?
Old 02-19-2005, 12:37 AM
dont know, is that in the area I described on these or up front like on the lt1's?
Old 02-19-2005, 01:19 PM
throw out bearing...hmm...now thats an idea there
but the clutch assembly is new...but who knows maybe they skimped out and did not put a new throwout bearing into it
and as of today, so are both clutch cylinders (master/slave)
the shop said possibly a shim is too tight or loose causing too much play inside
Old 02-20-2005, 10:08 AM
RoyO's Avatar
My car has done the same thing since day one. Mostly in 1st-3rd gears. I figure its a bearing inside. Its done for 75k miles so I'm not too worried about other than the noise.
Quick Reply: whining sound in cab/under dash? while driving...6 speed 99 SS
