GMPP LS6 CNC heads, TR224 on 114 LSA??
Old 02-19-2005, 10:25 AM
DannyR's Avatar
Default GMPP LS6 CNC heads, TR224 on 114 LSA??
Anyone using this combination? I am interested in rwhp/rwtq numbers. I know the driveability will be fine with a good tune and that more hp/tq can be made with different head and cam combinations......Just interested in information about this combination.
Thanks
Old 02-19-2005, 10:34 AM
cyphur's Avatar
thats a nice lookin vette bro! have you checked out the dyno section yet? you might have more luck there. i know those heads do put down some decent numbers, tho not quite as nice as TEA's Stg2 LS6 heads
Old 02-19-2005, 10:58 AM
DannyR's Avatar
Thanks for the compliment. I do enjoy the FRC. I will look into the Dyno section and see what I can find.
Well, looked in the dyno section, but couldn't find the information I am looking for. Hopefully, someone on the forum will have some info.
Old 02-19-2005, 04:23 PM
cbota's Avatar
Thanks
I just installed this cam with ls1 ported heads and my HP is in the sig. Its not tuned yet and kr pulled some timing so I should beable to get anothe 10-15 hp.
Old 02-19-2005, 04:40 PM
Ryan02SS's Avatar
The big intake ports on those LS6 heads are begging for a large cam, not a 224 grind or the like. The combo will work but a smaller intake port will work alot better with a TR224 grind. The AFR 205's, Rapid's Stage II's, TEA 1.5's are what I would be looking at if adding heads to a TR224 setup. HTH
Old 02-19-2005, 08:34 PM
DannyR's Avatar
Interesting, so an LGM G5X1 or X2 would be more effective for th LS6 CNC heads?
Thanks
Old 02-19-2005, 08:35 PM
DannyR's Avatar
When do you plan on getting your FRC tuned? I would like to know what gains you get?
Old 02-19-2005, 10:25 PM
98TAauto's Avatar
dunno if it helps.. but my auto made 399 with a 224 114 cam cam on tea 1.5 heads
I would think you should be over 400 with full bolt ons with a M6 and those heads... maybe 420ish-430ish?
Old 02-20-2005, 08:13 AM
DannyR's Avatar
Thanks for the reply. I would figure around 400. I wonder where the tq would be?
Old 02-20-2005, 10:41 AM
Viper's Avatar
380 ish
Old 02-20-2005, 05:39 PM
98TAauto's Avatar
ditto the 380ish roughly.... good for a M6.. either way your car should scream from a roll
Old 02-20-2005, 07:26 PM
DannyR's Avatar
Thanks Guys. Still gathering data. Any additional real time information would be appreciate.
Old 02-20-2005, 08:10 PM
Cal
Cal's Avatar
Thanks
Yes, you need to be looking at larger cams. A least something in the 230 degree duration range. TSP Magic stick, or even the cam I have (see sig.) Both are pretty streetable with a good tune and will make your vette go like hell.
Old 02-21-2005, 12:04 PM
DannyR's Avatar
Oh man, a run on the salt flats. I would love to do that. I haven't checked in to such an activity. Is there a web site one could go to for information on a top end run on the salt flats? And, thanks for the info on the cam.
