timing chain
Old 02-20-2005, 08:16 PM
yobabiesdaddy2001's Avatar
Default timing chain
When buying a timeing chain what types of things set one away from the others. Can all timing chains be used with slp underdrive pulley are Iam just limted to the slp version double roller?
Old 02-20-2005, 08:21 PM
JMBLOWNWS6's Avatar
ASP allready come machined now for clearance.
Old 02-20-2005, 08:23 PM
Default asp What
Uh what??? So slp s is not already clearance
Old 02-20-2005, 08:34 PM
JMBLOWNWS6's Avatar
Dunno y dont you just call them
Old 02-20-2005, 09:03 PM
01_SuperSlow's Avatar
What he said
I would just throw a JWIS in there and forget about the double roller, but that's just me.
Old 02-20-2005, 09:21 PM
sickss228's Avatar
I went with the rollmaster double roller and ASP pulley, I went with the double roller for a piece of mind when spinning the motor 6700+ RPM's on the bottle. The ASP also comes machined for the double roller
Old 02-20-2005, 09:26 PM
jrp
SN95 Director
jrp's Avatar
same here
Old 02-20-2005, 09:37 PM
CHRIZ28's Avatar
How new does the pulley have to be, to be machined to accept double roller? I plan on having TSP install a double roller when I go there for cam install and I don't want any suprises. Thanks
Chris
**Edit: Also, is there anyway of looking at the pulley to tell? I've got a appointment this Thursday with TSP, so I need to get this figured out. Thanks again.
Old 02-21-2005, 05:14 AM
I keep seeing you guys use ASP, are there any problems with Slp underdrive pulley and a double roller? THanks.
Old 02-21-2005, 11:15 AM
Bill Bowling's Avatar
Talking
[QUOTE=yobabiesdaddy2001]I keep seeing you guys use ASP, are there any problems with Slp underdrive pulley and a double roller? THanks.[/QUOTE}
I think the new SLP Pulley should be fine. I would not use the old SLP pulley.
Bill
