Whats needed to put rear O2's up front
Old 02-22-2005, 11:20 AM
CarsRFun's Avatar
Default Whats needed to put rear O2's up front
getting the typical long tubes error codes, what all do I need to put the rear O2's up front, any harness or anything like that, can they just plug up?
any links to places that would sell the harness if needed would be appericated.
I contacted LGm but have not heard back from them.
Thanks
jason
Old 02-22-2005, 11:40 AM
10 Second Fun Car
jlrz28's Avatar
Buddy of mine just plugged them in and had no problems.
Old 02-22-2005, 11:48 AM
jub jub's Avatar
I don't know about F-Bodies, but on Y-Bodies the plugs are different. In order to run the higher wattage rear O2 sensors up front you need adapter cables. I know LG Motorsports sells them.
Old 02-22-2005, 12:52 PM
CarsRFun's Avatar
i cant find them on their site....
Old 02-22-2005, 12:57 PM
2001 White Ws6's Avatar
They are interchangeable so they will work back or front. I think...
Old 02-22-2005, 01:25 PM
GuitsBoy's Avatar
Wait wait wait.... what car are we talking about here. On an f-body, front and rear are interchangeable. No difference in sensor at all, only in the wire pigtail length. Now on the vette, the rear sensor has a higher wattage heater than the front, as well as a 2 foot+ pigtail. The vette rear sensors will work without modification in an f-body as they share the same square 4 pin connector. However to use the rear vette sensors in the front of a vette with LT headers, you need an adapter, since the front vette 02 sensors have flat 4 pin connectors.
Old 02-22-2005, 02:07 PM
CarsRFun's Avatar
i have a Vette.. and need adapters i guess, just cant find them.
Old 02-22-2005, 02:18 PM
GuitsBoy's Avatar
You can buy the universal denso sensors which require you to solder or crimp your old connector onto the pigtail... not hard if you dont mind being bothered to do so.
Old 02-22-2005, 02:48 PM
CarsRFun's Avatar
I thought with O2 if you start cutting the lines you get more probs?
i hate GM for their damn O2's cause all kinds of probs.. for me at least
Old 02-22-2005, 03:03 PM
GuitsBoy's Avatar
Personally, I think its a big myth that splicing lines will raise the resistance perceptibly. I think theres far more danger in simple hit or miss manufacturing of the o2 sensors itself. I recently bought a brand new one that crapped out in a week and a half, exchanges that one for another identical sensor and have been driving fine the rest of the winter. Even if splicing it did raise the resistance, an adaptor would do the same.
Old 02-23-2005, 07:23 PM
Bill Bowling's Avatar
Talking
For a F-Body just buy the Bosch #13111 Vett Rear O2. They work great and got rid of my codes.
Bill
Quick Reply: Whats needed to put rear O2's up front
