ls1 cam degree kit with heads off?
Old 02-23-2005, 02:40 PM
cablebandit's Avatar
Default ls1 cam degree kit with heads off?
I am wondering which cam degree kit you guys recommend for doing a ls1 with the heads off and the motor on a stand? I see some are "set up" for doing it with the heads on and thats why I ask.
Old 02-23-2005, 03:16 PM
technical's Avatar
I didn't know you could degree a cam with the heads off.?.?
How do you know when the valve actually opens?
Old 02-23-2005, 04:52 PM
thunder sells a kit that does it with the heads off but its like 280
Old 02-23-2005, 06:03 PM
technical's Avatar
The website says it requires a modification for LS1's. Must be a magnetic setup that doesn't "stick" to the aluminum. Why don't you just put a head on?
Old 02-23-2005, 06:09 PM
tonyb's Avatar
Here you go.http://www.gearheadtools.com/16372.htm
Old 02-23-2005, 06:20 PM
good point...i could just lay a head on there with an old mls gasket
Old 02-23-2005, 07:32 PM
Flareside's Avatar
I just did this, it's easy. You'll need a dial indicator with a magnetic base, a small steel plate that you can bolt to the block somewhere (to attach the magnetic base to), and a degree wheel. Bolt the plate down to the deck, mount the base to it, then position the dial indicator right over the lifter.
Quick Reply: ls1 cam degree kit with heads off?
