H/C Upgrade Complete - 437rwhp
Old 02-24-2005, 10:52 AM
C5X2C's Avatar
Default H/C Upgrade Complete - 437rwhp
After a year of research, my H/C upgrade is finally done.
Basically went for the Tony's AFR solution:
AFR 205 milled .024
224/228 114 LSA
LGM LT with random cats
FAST 78mm Intake
30lb Fuel Injectors
LS6 ported Oil pump
Performance Dampner
Oil Catch Can
etc. etc.
I 've had the car back a week and haven't had much time to drive it due to our rainy weather.
After the initial round of tuning we got 437 rwhp, I am not dissapointed. We should probably find a bit more but that's not bad.
There are two issues we are dealing with:
1) There is a whistle under low throttle. Mechanic couldn't find the source of the noise. Is this something I need to worry about? I would think that this could be introducing more air that the PCM could know about.
2) About 1/3 of the time when I start the car after being fully warmed up, it won't idle and dies. RPM drop to 800 and then just drops until it dies. What is up with that. The tuner hasn't had a chance to look at it yet.
Thoughts? Thanks!
Old 02-24-2005, 11:02 AM
2c5s's Avatar
AFR 205 milled .024
224/228 114 LSA
FAST 78mm Intake
30lb Fuel Injectors
LS6 ported Oil pump
Performance Dampner
Oil Catch Can
etc. etc.
Thoughts? Thanks!
Congrats on the power. Idle is a hot start tune issue. Easily fixed. The whistle sounds like a small leak in the intake track. Check all of the intake track connections.
How much RWT was there. Can you post a graph?
Old 02-24-2005, 01:12 PM
Flareside's Avatar
What air filter? My car whistles at light throttle when I have my Halltech Stinger intake installed. With the stock intake, it's silent. Noboby else reports this with a Stinger, so it's just something *special* about my car.
Old 02-24-2005, 01:19 PM
DanZ28's Avatar
Nice numbers!
Didn't Tony start out with the fast 78mm then swithed to the 90/90 fast setup and gained 20 Hp?
As far as the hot start problem, it's all in the tuning.
Dan
Old 02-24-2005, 01:38 PM
Bad Seller Alert
getlifted's Avatar
Nice numbers with a fairly small cam. What was the torque?
Old 02-24-2005, 02:28 PM
mike c.'s Avatar
i made near the same power with a set of speed inc r.g.r st2 heads,stock intake,th-body and a smaller cam. i just got my afr heads today w/g5x3 cam,man i hope it's worth it.
Old 02-24-2005, 03:19 PM
LSUxBlake's Avatar
Nice numbers
Old 02-24-2005, 04:39 PM
Cal
Cal's Avatar
Excellent results with a cam that's not all that big.
Old 02-24-2005, 04:58 PM
Sport Side's Avatar
Nice Number.
How did peak torque end up looking?
Old 02-24-2005, 05:51 PM
Dustin@PremierAutosports's Avatar
Nice numbers!
Old 02-24-2005, 05:52 PM
C5X2C's Avatar
I will post the dyno graph when I find some time. I believe that the TQ was just over 400.
Old 02-24-2005, 05:59 PM
Mirek's Avatar
500 hp Motor
Congrats !
Old 02-24-2005, 06:55 PM
Spellbound's Avatar
If thats the AMW catch can, that may be the source of your whistle....My girlfriends car had that problem....just pinch one of the hoses going to it, and if its the catch can, the noise will go away.
Nice #'s btw!
Old 02-24-2005, 07:36 PM
John02SS's Avatar
Mine whistles to and I haven't been able to find it. I haven't checked the catch can though! I will though!
