AFR 205's w/ MS3?
AFR 205's w/ MS3?
What would you all think of this combo (66 cc heads)? Along w/ Fast 90 setup/4400 stall/3:73 gears/LT's. Do you think I would be better holding off and going with 225's and the cam Tony specs? I am wanting to stay stock bore/stock bottom end. By the way, TSP said this combo would work without flycutting.
I'd really consider going with the AFR spec'd cam or a custom design from Flowtech. Bigger isn't always better, and with so many cams on the market today, it seems difficult (if not impossible) to imagine sponsors investing the kind of research and development time necessary to produce a cam that, to at least some extent, universally satisfies the demands of the most popular engine configurations.
Josh
Josh
