HELP! broke exhaust gas vent line bolt?
HELP! ? broke rear bolt on coolant crossover line to vent steam on ls1 head
the bolt broke off in the head or block and i need to get it out.......rear passenger side.
That's what she said...
sounds gross! sounds like you need to get a centerpunch, drillbit, and an ease-out and see if you can get it out. i'm not sure what exactly that bolt goes into, if it's the valley cover, you can take it off, then use the ease-out. good luck!
an ease-out is kind of a reverse threaded drillbit/tap looking thing. you drill a hole in the bolt thats broken off, then hammer the ease out into it (lightly) enough to get a bite, then turn it to the left and it pulls the bolt out. i broke a valvecover bolt off in my head on monday and used an ease-out, worked great!
ok that sounds like a good idea but what kind of drill can i get to the rear of the head? and drill down? im screwd? i just installed the head last night and im not taking it back off!
