Stock Crank Weight?
Old 02-27-2005, 04:39 PM
Karlo's Avatar
Default Stock Crank Weight?
I read somewhere that the stock LS 3.622 crank weighs 143 lbs? If that true an aftermarket crank weighing appox. 50lbs is a no brainer upgrade??
Old 02-27-2005, 06:09 PM
CharlieLed's Avatar
Where did you come up with 143 LBS? I just put a stock crank on my bathroom scale, it weighs 51 LBS.... I never heard of anyone changing the crank to save weight.
Old 02-27-2005, 06:32 PM
Cal
Cal's Avatar
You really couldn't lighten the crank any or it would be out of balance, weakened, or both.
Old 02-27-2005, 10:08 PM
Karlo's Avatar
Default ??
I could be wrong and stand corrected if you are right.
Old 02-28-2005, 01:05 AM
Louis's Avatar
Stock is anywhere from 53-54.
The strokers are ~ 48-55 depending on manufacturer.
Callies typical LS1 stock stroke cranks are 44-45, and you can get them as light as 34.
Old 02-28-2005, 08:00 AM
11 & 7 Second Clubs
Race Car Driver's Avatar
142 lbs.?, Good Grief! The crank in my 622 doesn't even weigh 100 lbs.
Try 55ish for a LS1 crank or call an engine builder for the precise number.
Quick Reply: Stock Crank Weight?
