Timing chain
Old 02-27-2005, 09:09 PM
The Guy in MY 99TA's Avatar
Default Timing chain
I was wondering which you guys would choose... a Rollmaster double roller or a Crance adjustable Double Roller?
I really like the Crane but I can't make up my mind.
Josh S.
Old 02-28-2005, 05:32 AM
LS1Tech Sponsor
Slowhawk's Avatar
I like ussing the stock sprockets and a LS2 chain.I think it is $30 or so.
Old 02-28-2005, 08:05 AM
Z06PSI's Avatar
Same here......LS1 sprokets LS2 chain...
Old 02-28-2005, 05:44 PM
JR-CRUZN-C5's Avatar
Cloyes True Double Roller worth the $$$ and recommended by many engine builders!!!
JR
Old 03-01-2005, 03:44 AM
MelloYellow's Avatar
What is the LS2 chain like?
I prefer the Jwis Kettin stainless steel single chain..
Old 03-01-2005, 06:11 AM
2001WS6Vert's Avatar
If you order a chain for an LS1 from GM you get the LS2 chain. It is a production update. I found this out when I ordered a chain from the dealer and noticed the thicker metal on the links.
Old 03-01-2005, 03:56 PM
67Firebird455's Avatar
I bought the Comp Cams adjustable double roller, and was very happy with it. Not too bad of a price, at about $110. I would recommend the LS1 sprockets and LS2 chain, looking back at it now...
Old 03-01-2005, 03:59 PM
cyphur's Avatar
i'll be pickin up the LS2 chain when it comes time.
Old 03-01-2005, 05:29 PM
01_SuperSlow's Avatar
I recommend the JWIS chain.
The LS2 chain wasn't out yet when I bought my JWIS. Anyone got any pics of the LS1 and LS2 chains side to side?
Old 03-01-2005, 07:22 PM
I want some details/benefits of the ls2 chain and stuff like that. Why not buy something like a crane or comp or something like that? Not sure which it is but I wouldn't buy the 400 dollar chain b/c I think thats F***in b/s for a damned timing chain.... hell I'de rather do a belt then
Josh S.
Old 03-01-2005, 09:07 PM
Mike 01WS6's Avatar
Is what is the max power you should run on an LS2 chain? I may pick one up if it's only $30.
Old 03-01-2005, 11:14 PM
WS6 RULES's Avatar
I have 30k miles on my 02 WS6 and about to do a cam swap. Should I change the sprockets and chain or would I be OK just changing to the LS2 chain?
Old 03-01-2005, 11:51 PM
You'll be ok just changing the chain.
Old 03-02-2005, 02:46 AM
Nittany_marine's Avatar
Go with the LS2 chain. A few guys here (including me) are going with that chain. It will work with the stock sprocket. Good choice in my opinion.
Old 03-02-2005, 02:55 AM
Restricted User
CAT3's Avatar
If you dont need an adjustable set I agree with GM Chain, good roller. I am going with a F***ing BS $300 Cloyes Hex-Adjust with a JWISS Single Roller Chain. I dont like doubles cause the cam swap/oil pump and chain issues, with a single, its easier to swap out. As far as stock gears, look at the gears teeth for wear (sharp points/heavy wear on one side) and crack around bolt holes to check for replacement.
Old 03-02-2005, 07:52 AM
1BADAIR's Avatar
I installed a JWIS chain and 8000miles later when my engine went it was already loose.
Old 03-02-2005, 07:56 AM
SideStep's Avatar
Same here.....
Old 03-02-2005, 07:54 PM
Raise's Avatar
ls1 sprockets w/ ls2 chain here on h/c motor
Old 03-03-2005, 03:31 AM
98A4LS1's Avatar
Just to make sure, the LS2 chain will work on 1998 LS1 sprockets, right?
D%^n, I was quoted $58 from dealer yesterday. The part# was 12586482, right?
Also, I was told by the dealer, the LS6 oil pump part# is 12586665 $124.
Old 03-03-2005, 09:58 AM
bigdsz's Avatar
The LS6 oil pump should be less than $80 from the dealer otherwise you're getting screwed. Check out SDPC web site.
