1 for the engine master-How much oil in the pan when engine is running
Old 02-28-2005, 04:19 PM
GTS346's Avatar
Default 1 for the engine master-How much oil in the pan when engine is running
Here's the scenario, LS1 engine has 6 qt's in the pan, when engine is running how much oil would normally be left in the pan and how much oil would be running around the engine?
Old 02-28-2005, 04:25 PM
Boostaholic's Avatar
It depends on the engine RPM, at higher RPM more oil will be up top for sure.
Old 02-28-2005, 05:25 PM
GTS346's Avatar
Ok what about at idle, say 900rpm and at redline, say 6,500rpm?
Old 02-28-2005, 06:06 PM
2001CamaroGuy's Avatar
I would say at idle, most is in the pan....
at redline, most is in the valve covers.....
Old 02-28-2005, 06:33 PM
APeteSS's Avatar
Give it a try, hold the revs at redline and check your dipstick
Old 03-01-2005, 12:01 AM
GTS346's Avatar
If my engine had a dipstick and I had a spare pair of hands then maybe yes I could try that.
