ls6 oil pump what oil Pressure
Old 02-28-2005, 06:34 PM
sevanseriesta's Avatar
Default ls6 oil pump what oil Pressure
I installed an ls6 oil pump when I did the cam swap and nbow my oil pressure is lower then my stock pump was. I checked the ring it looks perfect and is not chewed up so i am just curious what my pressure should be at idle
Old 02-28-2005, 07:30 PM
Mike94ZLT1's Avatar
I have 55-60 at a cold idle, and 45-50 from a warm idle. I see 70-75 at 2500+ rpm when still on the cool side, and 60-65 when at 2500+ rpm and I've been driving for awhile
Old 02-28-2005, 07:32 PM
do you have a ls6 ported or stock. I get under 20 psi at idle and around 30 on a cold start
Old 02-28-2005, 07:34 PM
luv2spd's Avatar
I get around 40 psi at idle when fully warm. Its about 5 psi higher than my stock pump on average.
Old 02-28-2005, 07:36 PM
so what is wrong with mine
Old 02-28-2005, 07:41 PM
jrp
SN95 Director
jrp's Avatar
im at around 60psi at idle.
Old 02-28-2005, 07:42 PM
01_SuperSlow's Avatar
That is exactly the psi's that my oil pump runs. I have a stock LS6 oil pump.
What psi is your pump running at? Did you put a new o-ring in there?
Old 03-01-2005, 03:57 AM
ZR2877's Avatar
Mines a little over 40 at warm idle and a little higher when cold.
Old 03-03-2005, 08:47 AM
No I re-used the stock one.........
Old 03-03-2005, 09:52 AM
C5X2C's Avatar
I have a ported LS6 Oil pump. I am around 50 lbs at idle and 70-80 lbs above 3k rpm.
Old 03-03-2005, 10:24 AM
WOW, That sucks guess I have to take the front part of the motor off again. I do not want to do that again.
Old 03-03-2005, 11:31 AM
Restricted User
2001 Pewter WS6's Avatar
Did you score a cam breaing during the cam swap. I did once by accident and had the same oil pressure issues which eventually let to my motor going
Old 03-03-2005, 02:10 PM
greatwhite99's Avatar
How do you a score a cam bearing during installation? I am having similar low oil pressure issues after ls6 ported oil pump and cam swap.
Mike
Old 03-03-2005, 02:19 PM
I am also going to ask what do you mean by "score" a cam bearing.
Old 03-03-2005, 05:54 PM
ILLWS6's Avatar
Yup, Me too. I got it fixed immediately to save my motor tho. If it's not an o-ring issue this may be your problem. I hope not for your sake, It's an expensive repair.
Old 03-04-2005, 08:32 AM
My oil presure with the ported ls6 pump is like 30 at idle and 40 at 2200 RPM. Could it just be the o-ring slipped during the install? If so do I need to remove the pulley or can I just drop the pan down and get to it that way?
Mike
Old 03-04-2005, 09:29 AM
777's Avatar
you're not supposed to re-use the stock one...
Old 03-04-2005, 11:12 AM
JeffJeff's Avatar
I put in a ported pump when I did my h/c swap. I had the same issue with losing about 5 to 7 psi across the board. I talked with a local shop and they said you have to shim the pumps to get more pressue. I had them shim it and I reinstalled it. I gained 10psi across the board versus the stock non-ported one I had on before the h/c swap.
Old 03-04-2005, 12:47 PM
93octane's Avatar
I did the LS6 ported pump when the cam went in. The psi is much higher now. It was 40-45 at a warm idle, and now I get 60-60 at warm idle. I think it is worth the money ($125 or so).
Old 03-04-2005, 01:34 PM
Restricted User
Scratch or gouge it when the old cam came out or new one went in. Usually happens to the first cam bearing. If your oil pressure is down 20psi then shimming the oil pump isn't your fix ( you should never shim the pump anyway). Pull the cam out and see if the 1st cam bearing is scratched. If your fingernail catches in a groove when you scrape your nail across the bearing, then it needs replaced. Put it off now and replace your motor shortly there after... I scratched mine and noticed a 20psi drop in oil pressure immediately. Car seemed to run fine until I spun a main bearing. Sure wished I would have swapped out that bearing...
Quick Reply: ls6 oil pump what oil Pressure
