What determines the lopey-ness of a cam?
Old 03-02-2005, 02:25 AM
FstBlkz28's Avatar
Default What determines the lopey-ness of a cam?
I used to figure it was mostly the LSA that determined how much a cam loped. But after hearing some of the futural cams and a few others ... the 112 really doesn't seem to have the lope i'm looking for. Do i just need to go lower? Or are there other factors that account for the distinct lopey-ness of a cam like ramp rate? a bigger differenence in I & E duration?
tia
Old 03-02-2005, 02:26 AM
jrp
SN95 Director
jrp's Avatar
overlap
Old 03-02-2005, 02:37 AM
Nittany_marine's Avatar
Its the overlap that gets you that real "thump". I went from a 224 cam on a 112, to the G5X3 on a 114. The Latter of the two has more thump to it, b/c of that. If only I knew the specs...
Old 03-02-2005, 02:46 AM
SStrokerAce's Avatar
Overlap....
Which is the product of both duration and LSA.
A lower LSA or a higher duration will increase the overlap.
The seat timing is also something to look at on this too. A cam with a short seat timing will have less overlap and therefore less lope.
If you want more lope, you need a bigger cam in duration or a smaller LSA.
Bret
Old 03-02-2005, 02:49 AM
Cal
Cal's Avatar
There have been many, many threads on this. You need to use the search button, my friend. There is a mathematical formula for calculating intake/exhaust overlap in a couple of those threads. Having a split duration doesn't change the lope much, but it does make the idle rougher. Lowering the idle speed will increase lope also.
Old 03-02-2005, 03:18 PM
Blue Hawk's Avatar
Ramp rate will also play a role in the amount of overlap. For the same duration at .050, the cam with the most agressive ramp will have less overlap and less lope.
Old 03-02-2005, 03:22 PM
LS1_PNYTAMR's Avatar
overlap plays some roll, but tr224's lope harder then the f13, quite a bit of difference there in overlap, so it has to be something other then overlap!!!! for example.. my f14 114lsa cam i full expect to lope harder then a f13 on a 112, even tho the f13 has 7 and my f14 has 5.. the f13 just doens't lope.
Old 03-02-2005, 03:32 PM
JBGRAYTA's Avatar
check this thread out
https://ls1tech.com/forums/generation-iii-internal-engine/248916-what-makes-cam-lope.html
Old 03-02-2005, 06:57 PM
44mag's Avatar
try a cam on a 110 lsa. i have a gmpp asa cam 226/236 .525 .525 110 lsa.
shakes the whole car. lopes like a sob!!!!!
Old 03-02-2005, 08:11 PM
Sudz's Avatar
Lets hear your lopety lope lope!!!
Old 03-02-2005, 09:51 PM
Another_User's Avatar
Adding timing can reduce lope.
Quick Reply: What determines the lopey-ness of a cam?
