Head Questions!
Old 03-02-2005, 01:34 PM
ABadMother1999's Avatar
Default Head Questions!
I am thinking about buying heads this week. What do you suggest? I am kinda confused on what size valves I should go with and what size CC I should go with.
2013
Assy. 2.02"/1.57"/64cc
$1,395.00 pair
2033
Assy. 2.055"/1.57"/59cc
$1,395.00 pair
2031
Assy. 2.055"/1.57"/64cc
$1,395.00 pair
Which ones should I go with? I have a TSP grind cam (231/237 .598/.595 on a 112lsa) full intake/exhuast and stage 2 clutch!
What do you suggest and why? Thanks!
John
Old 03-02-2005, 02:01 PM
Boostaholic's Avatar
Do you want your compression ratio higher or lower? If you plan to go forced induction you probably want the bigger CC heads, if your going to stay N/A then smaller cc are fine.
Old 03-02-2005, 02:57 PM
Ill probably be N/A most of the time but I might spray an occasional 75-150 shot at it... What do u think?
Old 03-02-2005, 05:17 PM
Any suggestions?
