Engine now has high pitched whine
Old 03-03-2005, 05:56 PM
Berniempb's Avatar
Default Engine now has high pitched whine
I have a 99 Camaro SS M6 with about 60k and lately the engine has started to whine. The whining is noticeably more pronounced around tighter corners at slightly higher RPM's. I thougth maybe it was the power steering or even the synchros, but it whines constantly, even when the car is stopped in neutral and I just rev it. If yall have experienced this before or could give me some advice on where to begin to fix this, I would definitely appreciate it.
-Mike
Old 03-03-2005, 05:58 PM
LSUxBlake's Avatar
Possibly the alternator bearing? Is it a squeak or a constant whine?
Old 03-03-2005, 06:01 PM
Berniempb's Avatar
Its definitley not a squeak, its a whine. Some days it is not as bad, but on others I make one turn in low gear and it seems to set it off.
Old 03-03-2005, 06:02 PM
SMOKIN01TA's Avatar
probably the a/c clutch/compressor. just changed the one on my z71 it got constantly louder and i was affraid it was about to lock up and shread a belt.
maby the ps pump
Old 03-03-2005, 07:30 PM
Spellbound's Avatar
I have had a couple of expieriences with a whine...first one was the drivers side idler pully.....It had a catastrophic failure on a friday the 13th that stranded me for a few hours. Next was a whine from a amw catch can.
Old 03-03-2005, 07:45 PM
66deuce's Avatar
that's funny,i have a whine from about 2000rpms to 3000rpms.just installed the catch can last spring.hmm.
