Rear main?
Old 03-06-2005, 01:36 AM
Boostaholic's Avatar
Default Rear main?
Is it common to have rear main problems in ls1 motors?
I got my motor out today and noticed my rear main was messed up..
At least I found it!
Old 03-08-2005, 02:05 AM
LS1TECH Sponsor
Steve - Race Eng's Avatar
Default Rear main
If the rear main is bad I would suspect a balance problem with the flywheel, clutch or converter. Could also be a pilot bearing problem if it is a stick. You didn't specify whether you had a stick or auto. Did you replace any of these components in the past?
__________________
Steve Demirjian
Race Engine Development
Oceanside, Ca.
760-630-0450
web: www.raceenginedevelopment.com/
e-mail: race-engine-development@***.net
Old 03-08-2005, 07:18 AM
TT-TECH Veteran
Inspector12's Avatar
You say messed up? Do you mean installed wrong? Or are you talking about some thing else. I find it hard to believe that it messed up without some other event causing it. I am not trying to flame you. I know they are kind of a bitch to lighn up with out the right tools.
