Futural F15 (Ron Jeremy) clears stock pistons/valves?
Old 03-07-2005, 07:15 PM
99whitews6's Avatar
Default Futural F15 (Ron Jeremy) clears stock pistons/valves?
I think I changed my cam decision. Does the F15 Ron Jeremy cam clear stock pistons and valves?
Old 03-07-2005, 07:45 PM
SidewayzOZ's Avatar
Yeap.
Old 03-07-2005, 07:46 PM
Josh@KY-Turbo's Avatar
thinking of using that cam myself...
Old 03-07-2005, 07:57 PM
ferariguy3's Avatar
what are the specs on that cam?
Old 03-07-2005, 07:59 PM
99whitews6's Avatar
236/239 .600"/.611 111 LSA I believe.
Should it be installed Dot to Dot?
I hear everyone saying something about 108 ICL and I am wondering what that means?
Old 03-07-2005, 10:38 PM
SidewayzOZ's Avatar
It's on a 107 ICL, because 111 LSA - 4 degrees advance ground in = 107. You should definitely install it straight up (dot to dot).
Old 03-08-2005, 06:11 AM
99whitews6's Avatar
Thanks
Old 03-08-2005, 06:20 AM
SS346Ls1's Avatar
Good cam. Bigger then mine.
Old 03-08-2005, 09:11 AM
LS69TA's Avatar
It sounds amazing. I can't wait to fire mine up for the first time.
Old 03-08-2005, 03:27 PM
pdd
pdd's Avatar
good luck with it
Old 03-08-2005, 04:10 PM
LS1_PNYTAMR's Avatar
yea but a lot of ppl went to it from a f13 and lost power........ dunno if they ever figure that out, but if its got futral on it id trust it eitehr way.
Old 03-08-2005, 04:21 PM
nomorews6's Avatar
holy smokes ... sounds huge. Will that be streetable? Also, how do you think it will be compared to the g5xX line?
Old 03-08-2005, 04:49 PM
LS1Maniac's Avatar
It's perfectly streetable. My car drives like stock with the 4.10 gears. Cam pulls like a **** too, I absolutely love it. I unfortunatly installed the wrong keepers with my Manley springs and retainers and destroyed my valves but I should have it back on the road soon. I'll be getting track times as soon as I get it back and re-tuned. I have a dyno graph too, I'll throw it on here as well.
Edit: Here's my dynograph overlaying my bolt-ons only graph before the dynojet corrections.
Old 03-08-2005, 05:06 PM
i just wonder who big a deal drivability is gonna be. i am planning on using this cam and a TCI 4500 stall. this car is my daily driver and will see the interstate everday. How bad you you think my 3.23 gears would be? i dont mind being extreme as long as it is worth it.
Old 03-08-2005, 05:46 PM
LS69TA's Avatar
The X3 is .600/.600. Just a little smaller on the lift. Not sure about the duration. Lots of guys are running these big cams in daily drivers and not having any problems. You'll just have to change springs more often than the weekend guys.
