F13 and F14 Dyno graphs???
Anybody have anydynographs of motors running f13 or f14 cams?
I'm trying to decide between the two and I'd like to see the power curve down low to get a better feel for low end torque and power. I know both these cams are not low end torque cams, but I'm trying to see how much they give up down low.
Futral says the f13 has a 2500-6800 RPM range and the f14 a 3000-7000 RPM range.
Also, how does the idle sound on the two, or better yet, anybody have any sound files of either of the two cams?
Thanks...I'm getting close
The graphs are almost identical. I don't have a host for my graph at the moment...but.. it made 376, through a 12 bolt.. stock ls1 intake.. stock pulley.. mail order tune. From 5k-7k it holds over 355 at the wheels.... and doesn't seem to ever really fall off. I shift it at 65-6600.
And.. It ran the times in the sig.
Originally Posted by Dayzed TA
I am also trying to decide between these two. I think I will call Allen.
SS346LS1, I'll aim you tonight sometime...my schedule is pretty full the next few days, it's taken two hours to finish this post!!
If you want, you can email them to tim.sheets@bently.com
i called.. i wound up getting the f14 on a 114 lsa since im spraying... no spray, f14 on 112 lsa.. i called wanting the f13, and i have only 3.73's and a smaller stall right now, but im only getting a yank ss 3600.... all 3 cams, 13,14,15 all make tons of tq down low somehow...
Originally Posted by freakynipples69
I just ordered a Fm14 from them, but I'll be running 3.73's with it. I'll let you know how it goes with that setup. I am guessing 3.73 will be efficient enough......i hope.
Here is the F13 Graph. You can do a search in the dyno section for my name and find out about the cam more.
Graph of my F13 tuned by FMS
I know the thread isn't about how to do a cam swap but are you guys that run cam only changing valve springs,retainers,pushrods,and possibly other parts in the heads?
I am looking for the a good cam swap as well just wondering what was involved. 430rwhp sounds good to me!
