Stock Rocker Arm Q
Old 03-08-2005, 07:49 PM
Bluehawk27's Avatar
Default Stock Rocker Arm Q
Did a cam swap, had it dyno tuned and everything. I just set a SES code and now im noticing a ticking noise coming from the drivers side. I ASSumed that once i tq'd the rocker arm and finished the install i would be done. Should i get back in there and check the Rocker arms and retorque them?
Thanks
Old 03-08-2005, 08:53 PM
LS1s R US's Avatar
Wouldn't hurt to take a quick look, what was the code ?What kind of spring did ya use with the cam install?
Old 03-08-2005, 09:13 PM
calongo_SS's Avatar
Did you turn the engine over and do a second pass w/ the torque wrench? Lock tite? Can't hurt to check them the valve covers don't take too long to get off.
Old 03-08-2005, 10:17 PM
Bluehawk27's Avatar
I used PRC duals did the whole loc tight and 2 pass thing. I guess i'll find out for sure when i pull the code tomorrow.
Old 03-09-2005, 09:32 AM
LS1s R US's Avatar
Yeah let us know what the code is!
