Identifying an LS1
Old 03-09-2005, 01:31 PM
Andy1's Avatar
Default Identifying an LS1
I am considering buying a pull out motor complete with acc, PCM, and harness. To keep it "honset", I'd like to know how to best verify the model year by looking at the motor and/or it's code. I found this thread https://ls1tech.com/forums/showthrea...fying+year+ls1 in my search, but the info only goes up to year 2000 (Z). I would appreciate info on the codes for 2001 and up. If there's another thread that covers this, then please direct me to it. A pic of where the code is located would be helpful too.
Thanks,
Andy1
Old 03-09-2005, 01:37 PM
Wnts2Go10O's Avatar
what year car is it out of?
Old 03-09-2005, 01:39 PM
LS1s R US's Avatar
99 -00 has 853 cast on head 01-02 has 241 cast head! Number is at front of valve cover on lower side! Maybe this will help!
Old 03-09-2005, 01:42 PM
jrp
SN95 Director
jrp's Avatar
some late MY00 cars got 241 heads.
Old 03-09-2005, 01:49 PM
Boostaholic's Avatar
98 has 806
Old 03-09-2005, 02:09 PM
Andy1's Avatar
Since I will be buying from a salvage dealer, I may not be able to see or verify which car it actually comes from; ergo my need for reading the code.
Guys, if I can't use the head casting number as gospel, then I'd really like to be able to read the code.
Thanks,
Andy1
Old 03-09-2005, 02:13 PM
jrp
SN95 Director
jrp's Avatar
can you get all the codes and then come back and tell us. we can better help you that.
Old 03-09-2005, 06:45 PM
Andy1's Avatar
I appreciate the offer, but I'd like to be able to identify the motor on the spot. Actually, all I really need are the codes for the year of the motor, as I think the other stuff is either un-necessary, or can be identified visually....can't mistake it for a LQ4 or an LS6.
Thanks,
Andy1
Old 03-09-2005, 06:47 PM
SS346Ls1's Avatar
Yep. Mine is a 2000 and has 241 heads.
Old 03-09-2005, 06:48 PM
SS346Ls1's Avatar
Thanks,
Andy1
Read the part number on the intake.... check and see if its an ls6 model. If so... then you've got an 01-02 motor unless it was swapped. Then check the head casting number...
Old 03-09-2005, 06:52 PM
jrp
SN95 Director
jrp's Avatar
Thanks,
Andy1
well it'd be easier if GM only used one set of pt# per year but they use multiple part numbers for the same parts often superceeding (sp) others. thats why i say it'd be easier to get the numbers first so we could help you out.
Old 03-09-2005, 10:23 PM
Andy1's Avatar
Well, if that's how it has to be, then I'll do what I can to get the numbers first. In the link I provided in my first post, the following:
"The tenth [character] is model year v= 97 w=98 x=99 z= 2000 I don't know what they did after that"
So I assume there is nothing similar in the 2001 and later part numbers stamped on the block?
Andy1
