OK...Same duration and LSA but different lift, what happens ???
Old 03-09-2005, 04:32 PM
13 Second Truck Club
storm5.3's Avatar
Talking OK...Same duration and LSA but different lift, what happens ???
Say you have two cams w/ the same durations and same LSA's but one cam has a higher lift than the other, what happens different between the two ??? Sorry for my stupidity, but I was just sitting here brainstorming...Zed
Old 03-09-2005, 05:05 PM
jrp
SN95 Director
jrp's Avatar
well the higher lift will be more agressive and have more lobe area. is it something you'd really notice in terms of HP all things being equal, not much. assuming your talking an XE vs XER lobe
Old 03-09-2005, 05:13 PM
Kurtomac's Avatar
ok same durations same lsas but different lift what happens......the valve opens farther, thats what happens
Old 03-09-2005, 06:31 PM
storm5.3's Avatar
Smart *** !!!
Zed
Old 03-09-2005, 06:49 PM
Unaffliated Racing's Avatar
It would depend on the head flow. If the head could benifit from some extra flow it would be great...if it can't it would be merely a waste of time.
Old 03-09-2005, 07:12 PM
Kurtomac's Avatar
Originally Posted by storm5.3
Smart *** !!!
Zed
Old 03-09-2005, 07:33 PM
APeteSS's Avatar
So does anyone have an idea of what max lift for stock heads should be? I'm just guessing that about .590-.600 would be about the most lift worth it with stock heads.
DaddySS's Avatar
assuming the lift is within the capacity of the intake and head to flow, more lift equals more torque - no?
Old 03-09-2005, 07:45 PM
ChucksZ06's Avatar
The average amount the valve is open will be increased which (everything else being equal as you hypothesize) gives potential for more air to enter the cylinder. The area under the curve is increased like increased duration or more aggresive ramp rates. I do not think idle quality is affected as adversely as increasing duration. The cam is like the on off valve on a faucet in that if you open it further(increased lift) more water will flow in a given amount of time. More duration increases the length of time valve is open. That is a crude explanation but it sometimes helps to think of these things at a basic level.
Old 03-09-2005, 07:46 PM
APeteSS's Avatar
Sure, assuming you're actually improving the cylinder filling/ VE. An engine's peak torque is always where it fills it's cylinders best.
Old 03-09-2005, 07:55 PM
LS1Tech Sponsor
Slowhawk's Avatar
A higher lift can make a small Cam have a "bigger" Cam power in the upper rpm range.Meaning the small Cam idle/drivability but the power of a bigger Cam.
Take a TR224 on 112 Cam (.565 or so lift)and compare it to a 220 on 112 Cam but have XER lobes with .600 lift.The 220 will make more power everywhere but idle/drive much tamer. Of course the 220 Cam would have to be ground just right to compare.
Old 03-09-2005, 11:15 PM
storm5.3's Avatar
Talking
Cool thats what I wanted to know,Thanks guys...
Zed
