100 mile oil change after cam install?
Some one told me that I would have to change my oil 100 miles after my cam install in order to clean out any debris that might have accumilated. Is there any truth to this?
cool. thanks guys i am getting it installed this week and will have some dyno numbers hopefully by next week.
04 ZO6
FM 13 on a 112 + 2
LG longtubes/off road pipe
Shanner TB
Halltec Trap Intake
Pulley
Stock exhaust.
What kind of numbers do you'll think I will hit?
04 ZO6
FM 13 on a 112 + 2
Shanner TB
Halltec Trap Intake
Pulley
Stock exhaust.
04 ZO6
FM 13 on a 112 + 2
Shanner TB
Halltec Trap Intake
Pulley
Stock exhaust.
04 ZO6
FM 13 on a 112 + 2
Shanner TB
Halltec Trap Intake
Pulley
Stock exhaust.
It doesn't hurt to change the oil after a cam swap. Not as essential as after a head swap, but its usually better to break a cam (even a roller) with straight dino oil (not syn) for the first 250 miles or so, then go back to synthetic.
The absolute hardest moment for a cam after install though is the first 5 seconds before the oil gets to it. Make sure it is well oiled.
If it were me i would absolutely change the oil 100 miles after a cam swap! With a new cam you're going to use assembly lube right? I'd want to flush that out of there pretty soon, as well as any dirt which probably got into the engine during the swap.
Originally Posted by SS346Ls1
Yea.. I used assembly lube.. its called dipping the cam in oil
Race your car!
I agree, I have a cam swap goign on with my car early next week. It's about 40 miles from the garage to my house, I figured I'd drive it home, swing by a buddy of mine's houes on the way to extend the trip another 20 miles, and change when I get home.
No matter what kind of oil you use, or what you are having done to your car.... if the motor was apart, it's always a good idea to change the oil after.
On a related note... patman, which filter has the highest flow for our cars ( that you can pick up in a local auto parts store ) ? With the intervals that I change my mobil 1 0-40wt, ( every 1500 or so miles, which is about 3 months with me ) I'm not as concerned about the filtering as I am the flow. Thanks.
can i do the 100 miles with dino oil?
