Centerbolt Valve Cover Question
Old 03-12-2005, 08:22 AM
AFTICA's Avatar
Default Centerbolt Valve Cover Question
I know the centerbolt valve covers from the 5.3's and 6.0's fit the LS1/LS6 heads, but is there any difference in the PCV fittings or any other issues?
If the PCV fittings are different, can you simply swap out the fittings from your existing heads or any other simple fix?
Old 03-12-2005, 02:44 PM
99ssleeper's Avatar
Yes, I have seen some CBVCs that have no pcv tubes....I dont know which engines use what valvecovers though. The fittings are cast into the valvecovers so I doubt there is any change of swapping them.
Old 03-13-2005, 10:46 AM
AFTICA's Avatar
Has anybody seen or used 5.3 or 6.0 centerbolt valve covers that have the correct pcv fittings?
