bank 2 not firing and no Fuel
Old 03-15-2005, 08:52 PM
sevanseriesta's Avatar
Default bank 2 not firing and no Fuel
ok so skinnies rdhzrd and i are over here working on brians car and this is the farthest point we can get to
we have a test light and it lights up to constant power on the driver side but not the passenger
we have a voltmeter and it reads 11.41 on both sides of the engine
so then we unplugged the coil packs on both sides and stretched the wiring harness across the engine bay and when we plug the driverside pcm side harness to passenger side coils and bump it over the coils fire (russel(rdhzrd) was holding the plugwire in his hand and can attest to fact that is hurts like motherfugger)
so that means the coils and coil harness for all 8 cylinders are good and for some reason the passenger side pcm side of the harness is not telling them to fire or is not suplying the power for them to fire. Not to mention there is also no fuel. We have checked all fuses and they are all in working order and in the same place......... What is wrong
