Biggest cam without having to check/change springs all the time?
Old 03-17-2005, 01:25 PM
Red91vette's Avatar
Default Biggest cam without having to check/change springs all the time?
I was wondering what the biggest cars you guys are running in your car without having to check/change your valvesprings every 5k miles or whenever you need too. I want to be able to do a cam swap, and put in whatever springs I need and just drive the car. Not worrying about anything moving or getting messed up. So lets hear the set ups guys! Thanks.
Old 03-17-2005, 02:02 PM
black_knight's Avatar
My cam was designed with spring longevity in mind...
Old 03-17-2005, 02:27 PM
11 & 7 Second Clubs
Race Car Driver's Avatar
.650 lift.
Old 03-17-2005, 03:01 PM
Derek98z's Avatar
there are so many variables to this question. Which springs do you want to run first off?
Old 03-17-2005, 03:05 PM
luvmeZ28's Avatar
ive been curious about this too. i hope to be doing a cam swap soon.
i want TSPs 228 with the XER lobes. would comp 918s be good enough?mi too do not want to have to worry about changing valve springs once a year.
Old 03-17-2005, 03:19 PM
A little bird told me that it was ramp rates that kill springs, so I don't know if XER is what what you're looking for...
Old 03-17-2005, 03:20 PM
Of course, there's also the question of how high it will be revved...
PM me for info on my setup.
Old 03-17-2005, 03:26 PM
Derek98z's Avatar
Yep, and how much lift compared to springs max
Old 03-17-2005, 03:27 PM
Cal
Cal's Avatar
It all depends on how you drive it. If you rev the snot out of the engine every day like I do, you will need to check/replace the springs once a year, even if you have stock springs. They all lose tension after a while.
Having said that, if you stay off the rev limiter, combine comp 918's with a TR224, you should be good for 40,000 miles. I put 15,000 miles on that combo, checked the springs, and they still had 130 lbs seat presure.
Old 03-17-2005, 07:02 PM
Red91vette's Avatar
I would get the appropriate spring to match the cam, but that doesn't nessacarily mean that the springs will last 50k miles. I know some of the bigger cams, MS3, G5X3 etc will not be good for long spring life. So which cam would? I was considering the FM11 or FM12 maybe, or the TSP 233/239? I wonder how long it would need for maintaince for a cam like that. What cams are basically maintaince free (to a certain extent obviously) that make the most power, or are the biggest. Black knight, what is your set up? Anyone else have any cams that they have that they don't do any maintaince on? Post up some specs and milleage so far you have put on them maintaince free! Thanks.
Old 03-18-2005, 10:44 AM
EDC cam. Set up for street/strip and easy on the springs. Optimized for my boltons and stock heads.
Old 03-18-2005, 11:03 AM
Red91vette's Avatar
What is the specs on the cam? Do you have any dyno or track numbers?
Old 03-18-2005, 11:30 AM
Race your car!
JL ws-6's Avatar
918's and a cam in the 220ish duration and 580 ish lift should get you to around 400 hp to the tires with the needed boltons to make it work, and should be good for at least 25K, probably longer than that if you are easy on the car.
Eastside just got thur doing a cam install on my car, and I went with a cam like metioned above, got me 402hp to the tires thru the 12 bolt and steel driveshaft.... so with a sotck 10 bolt it would have been in the 415 range easy, and I don't expext any issues with valve springs for a long time.... or at least until I get into the motor again.....
Old 03-18-2005, 12:12 PM
The specs are... well, I don't know how much I'm supposed to say. It's more than 220 and less than 230.
As for track and dyno, since it's not in the car yet, I'll have to get back to you on that!
Old 03-18-2005, 12:37 PM
jrp
SN95 Director
jrp's Avatar
ed doesnt mind giving away .050 specs as those wont tell anybody **** and they dont know the lobe he used
everybody knows my specs 238/236 .586/.589 112+0. i've seen a few peoples FTI grinds, interesting stuff dependent on there application
Old 03-18-2005, 01:35 PM
Yeah, I know. It just sounds more mysterious this way
LOL, in all seriousness, I'll post up the .050 specs when I get home and have the sheet in front of me.
Come to think of it, isn't your cam "easy on the springs," what with being a road race grind?
Old 03-18-2005, 01:51 PM
jrp
SN95 Director
jrp's Avatar
we all know how people love secret specs
yes ed chose my lobes for valvetrain stablity and longevity. i plan for alot of HPDE's
Old 03-18-2005, 08:16 PM
MUSTANGEATER's Avatar
I would get the springs from Ed just to make sure you get em right. All the FTI cam's I've seen all perform really well....
Old 03-20-2005, 01:26 PM
BTW, mine's a 229/226 .579/.569 112 LSA... not that that will tell you much.
Quick Reply: Biggest cam without having to check/change springs all the time?
