Graphite or GM MLS?
Old 03-17-2005, 06:53 PM
mr2guru's Avatar
Default Graphite or GM MLS?
Just did a ton of reading up on these two....so,
Would the graphite ones be ok for H/C (~430whp) +100 shot? Strong enough?
Stock bore etc...
I think the graphite ones are more reliable at sealing but the MLS would hold more cyl pressure.
Either way I'll be using ARP head studs.
-Jim
Old 03-17-2005, 07:16 PM
ROGERSPERF.'s Avatar
I would use the MLS but you have to make sure the head and block serface are dead smooth.
Old 03-17-2005, 09:00 PM
mr2guru's Avatar
Yeah I would have no hesitation using the MLS if the block was recently machined. But it isn't. The heads are mirror finished but the block will not be after I removed the stock heads.
Old 03-17-2005, 09:30 PM
strokedls1's Avatar
The MLS gaskets are nice as they make future swaps much easier. Clean the block surface and check block and heads with a straight edge. Make your decision based off those results.
