Trex/MS3 and 6.0 heads
I was thinking about running the Trex cam or even the MS3 cam with stage 3 6.0 heads.... Stock deck height and stock gasket thickness. Would these heads be ok for this cam or would it be better to go with the 5.3's or LS6's for compression reasons? I'm worried about compression being to low with the 6.0 heads and the cam overlap being to large with these heads. Do you guys think this setup would work well or a waste of money. If it would work, what type of numbers would this setup put down with all the bolt ons?
I maybe wrong about the whole compression aspect of it, but I just want to be sure and double check with you guys. I don't want to go spend the money without knowing what type of trouble i'm getting myself into.
-Trevor
-Trevor
Those heads are good turbo or supercharger heads. Not very good for NA or Nitrous. Get the 5.3s or LS6s. If you are wanting something for a big valve then go witht he LS6s.
