Need help, stumbling badly after sitting all winter
Old 03-22-2005, 03:30 PM
kpowr82's Avatar
Default Need help, stumbling badly after sitting all winter
So it's pretty nice outside and I decided to pull the SS out of the garage and go for a spin.
It seems like anything near half throttle and above causes the car to stumble. I'm about to do a PCM reset and see if that solves anything.
Here is a little background:
I got rid of my TSP true duals because of ground clearance issues I was having. I bought a Hooker Cat-Back and used the Kook's ORY. The y was banging badly and the car began misfiring (false knock). Well, I have since removed the y since for the life of me I can't get it stop banging.
I have gone back to the TSP setup until I get my Lanes which will be soon hopefully. Anyway, I don't think it's misfiring because the SES light would be flashing. It feels like the PCM is just pulling timing.
Anyone else experience this? I could use all the help I can get.
Thanks,
Matt
Old 03-22-2005, 03:32 PM
kpowr82's Avatar
I already scanned for the SES codes, and the only ones there are emissions related (AIR and rear o2's). I have autotap so I can make some logs if you guys want to see anything that might be helpful. Just let me know what parameters you'd like me to log.
Thanks again
Old 03-22-2005, 04:18 PM
kpowr82's Avatar
Alright, I reset the PCM and just got back from driving about 15 miles. The stumbling is a little better, but is still very noticeable. Also, it seems to happen only in the 1800-2500 rpm range. It doesn't stumble at all at WOT.
My duals have real Shi**y welds. I mean real Shi**y, if I sent you guys some pics you'd be like WTF? But, they've looked like this since the end of last fall. Think it could be the cold air combined with an exhaust leak?
I might run some STP fuel system cleaner through for the first time. I've only got 20,000 on the clock and she's been started at least every other week for 20 minutes or more every winter while stored.
Anyone?? I suppose the next step would be to pull the plugs, but like I said before this doesn't happen at WOT.
Old 03-22-2005, 04:23 PM
white2001s10's Avatar
put in a fresh set of plugs and see how that goes.
Old 03-22-2005, 04:53 PM
mike c.'s Avatar
i'm having a problem too. my car runs good but,it's idling around 1,400rpm's when it should be at 950rpm's. i already have new plugs.
Old 03-22-2005, 04:57 PM
kpowr82's Avatar
Hey, get your own thread damnit
I'd rather not pull the plugs just yet. I'd like to exhaust any "easier" options first. Thanks for the reply though white2001s10
Old 03-22-2005, 05:51 PM
Bluehawk27's Avatar
did you use fuel stabilizer before storing it? the fuel may have just gone bad.
Old 03-22-2005, 07:05 PM
you're welcome,
and that WAS the easy option
Old 03-22-2005, 10:38 PM
kpowr82's Avatar
Okay, I'll guess I'll pull the plugs. It's not really that bad considering I've deleted AIR and have LT's.
Could it be that the maf is bad or the sensors are dirty? At WOT the PCM no longer uses the MAF when delivering fuel right?
Old 03-22-2005, 11:00 PM
ta12sec's Avatar
you probaly get away with out pulling the plugs. Alot of the performance cars do this after sitting (porsches do it if they sit for a week or 2) italian cars are famous for it thats why they call it an italian tune up. go out and run the car hard it will clean the plugs out 99% of the time.
Old 03-22-2005, 11:04 PM
kpowr82's Avatar
Hopefully it will work itself out. But if it doesn't I'm worried I may be causing more damage by floggin it. We'll see.
BTW Brad, are the same ta12sec on sembmusclecarclub.com? If so, PM me, I'd like to have some work done if you're still available.
Old 03-22-2005, 11:12 PM
Raise's Avatar
i agree with BlueHawk27, u may have some nasty fuel. always put fuel stabilizer in if it will be sitting for more than a week or two....if u didnt already
Old 03-22-2005, 11:48 PM
ta12sec's Avatar
Yes I am the same
Old 03-22-2005, 11:51 PM
kpowr82's Avatar
Well, I only had about a quarter tank before I stored it. I filled her up on Friday which is when the stumbling began. I thought for sure it was because the pavement was cold and I wasn't getting **** for traction with my Nitto's. I wrote it off as a traction problem cause that's what it feels like. The gas is brand new Marathon 93.
Old 03-23-2005, 08:35 AM
Raise's Avatar
i always store my car for the winter with a full tank and stabilizer. i was always told it was best to store with a full tank. also, store it on jack stands and/or take the wheels and tires off to prevent flat spots and cracking.
Old 03-23-2005, 08:52 AM
PewterZ28's Avatar
Hey I'm not going to steal your thread but I thought I'd mention I am also having the exact same problem. I had new plugs put in last Fall so I doubt that is the problem. It idles horribly until the engine is completely warmed up but even then it still idles around 1400 rpm. Weird.
Old 03-23-2005, 10:11 AM
Bluehawk27's Avatar
You should have stored it with a full tank of gas and stabilizer. Storing it with a 1/4 tank will allow condensation to form in the tank. Unfortunatly that could mean you have water in your fuel.
Old 03-23-2005, 10:15 AM
mike c.'s Avatar
nevermind,i fixed it. runs perfect now.
Old 03-23-2005, 10:54 AM
kpowr82's Avatar
Hopefully that is what it is Bluehawk. I'll put some fuel treatment in there and run this gas out, see if that helps.
mike c what did you do to fix your problem?
