What Would Be The Difference W/ These 408 Setups?
Old 03-23-2005, 05:02 AM
BoneSS's Avatar
Default What Would Be The Difference W/ These 408 Setups?
Setting up a 408 for mostly n/a, some nitrous, probably 150-200, 300 if I get greedy. Besides price, what about strength:
Callies 4.00" Racemaster crank
-Manley 6.125" billet rods.
-Diamond pistons w\rings
-Fedearl Mogal bearings
-ARP main studs
or
Eagle 4.0 strock crank
Eagle 6.125 H-Beam rods
Mahle forged Pistons
Federal Mogul race bearings
ARP main studs
Old 03-23-2005, 07:15 AM
v8maro's Avatar
I'd go with the eagle stuff, doesn't weigh much more and it is virtually just as strong. I am going with the same setup (eagle) from APE and i'll be spraying 300 DP, and I was told that the motor could take that all day long without problems.
-Steve
Old 03-23-2005, 09:55 AM
MeanWS6's Avatar
another vote for Eagle
Old 03-23-2005, 10:21 AM
half-n-half's Avatar
Default sorry boneSS
boneSS sorry to kinda hijack the thread but i actually have a related question and dont want to overload the site with a million threads.
So here is the question, what is everyones feelings on the iron 6.0 block? is it a bad idea? also what about a 4.125in stroke, i figure that they make the crank why not use it, i understand the side loading on the pistons is worse with that crank and a 4.030 bore,however is it so bad that using that crank is a bad idea?
Thanks
louie
Old 03-23-2005, 01:47 PM
BoneSS's Avatar
Callies 4.000" Stroke Forged Crankshaft
Callies Ls1 Forged H Beam Rods (ls1 Specific)
Diamond Forged Pistons
Diamond 4130 Chromemoly Wrist Pins
Diamond Proselect Ring Set (file Fit)
Federal Mogul Main Bearings (152m)
Clevite Connecting Rod Bearings (cb663h)
Arp Main Studs
Arp Head Studs
Old 03-23-2005, 06:50 PM
kumar75150's Avatar
i'd go with the top setup
Old 03-23-2005, 11:18 PM
JZ'sTA's Avatar
I would go callies just for ease of mind.
If it was totally NA then eagle would work, however once the nitrous comes on your gonna want more.
150 will be 250 in no time.
Old 03-24-2005, 03:35 AM
BoneSS's Avatar
How about Diamond vs Mahle pistons. The 3 setups above are 3 setups by 3 different unnamed sponsors. Trying to decide on a package. Thanks guys.
Old 03-24-2005, 05:27 AM
LS1Tech Sponsor
Slowhawk's Avatar
I use the Eagle 408 APE setups and 500+rwhp is the norm.They can withstand 800rwhp.
Old 03-24-2005, 10:45 AM
Beast96Z's Avatar
I went with the Callies crank and eagle rods. I'm sure you can swap some stuff up if you want, but the major price diffrence will be in the cranks. If it was N/A, I'd go eagle, but for nitrous, I wanted the piece of mind.
Old 03-24-2005, 02:23 PM
DAPSUPRSLO's Avatar
The upgraded callies rods are quite a bit more expensive then the callies comp star rods too. They are both ls1 specific. I believe the comp star rods are made over sees but don't quote me on that. Nick or Chris @ APE can chime in on this.
Old 03-24-2005, 05:32 PM
BoneSS's Avatar
Thanks guys, keep the input coming...
Old 03-24-2005, 05:53 PM
Revelation222's Avatar
LOL that 8k is burning a hole isnt it. I thought you said earlier in the other thread that you didn't want nitrous>? I just curious as to why you changed your mind.
Fastest set up for the cash? If so then you got it right. BE prepared to buy nitrous every other week though.
Take Care. And good luck.
Old 03-24-2005, 05:54 PM
Oh and I would go with the Callies. Nothing like peace of mind.
Old 03-24-2005, 06:49 PM
BoneSS's Avatar
I thought if I was going to build a 408, I might as well build it strong enough for either nitrous or fi while I was doing it b/c I know I will get bored. It is deciding the nitrous or fi route that is the hardest thing. I have more than this allowed in the budget, but I don't know where to go w/ it and if I want to go w/ this much in my car anyway. Pretty close to deciding to put the money into the car though. Nothing else to spend it on Knock on wood.
Old 03-24-2005, 07:01 PM
If you go with the 408, I doubt you would have enough to boost it (properly)afterward, and if you build it for boost you will use a lower comp piston so nitrous wont do you much good if you can't afford a blower first.
You would have enough for a cheap forged 347 built for boost, and a few choices of FI method. Even that will be close when its all said and done.
Or you could do the built 408 with a higher compression with a big shot on it for fun. However, a 12 bolt or 9" would be even more of a priority.
Just think about how you drive, and what would be the most fun to get behind the wheel of every time you want your adrenaline fix.
Old 03-25-2005, 03:46 AM
BoneSS's Avatar
Thanks for the advise! I'm just trying to get some prices on everything now. It might be best for me to build a 346, sell my present oen (has 30k on it) and get a PTK or Phamspeed kit.
Old 03-25-2005, 03:53 AM
Uthinkso's Avatar
Allow me to shed some light. The Eagle Products are very good, both rods and cranks. We have gone to using the Compstar as our go to LS1 rod simply because it is an LS1 Specific H-Beam. We have built countless 408 engines with Eagle Cranks and Compstar rods and not one of them have had issues. We have heard of power numbers closing in on 900rwhp and not one sign of fatigue in the parts or loss of performance.
With that being said the Callies Racemaster cranks are also very nice. While they are slightly lighter, that isn't their main selling feature. The counterweights are knife edged, the heat treat of the crank is more severe, and over all it is just built physically stronger. In short it is built to withstand whatever you can throw at it. A calssic situation of getting what you pay for.
Not to get too deep on the issue of 4.125 stroke Iron 422ci Engines. There are a few reasons why this isn't the most advisable idea. First and foremost you limit yourself on piston selection, of course it has to be a custom piston anyway. Your Compression Distance is very short for one, just barely over an inch. Outside of the fact that you won't have as much material through the top of the piston, there are also piston to valve issues to consider. Feel free to give a call at the shop or PM me if you'd like to get into this further. Oddly enough, the Iron block requires no counterweight clearancing with the 4.125 arm. I was shocked.
Hope that gives you both some insight into the motors you are considering. If I can be of any further service feel free to give a call at the shop.
Old 03-25-2005, 06:54 AM
7 Second Club
10.5 Dave's Avatar
Location: Grove City Ohio/Port Washington L.I sometimes
Callies is also the only Gen 3 crankshaft that I know of that sells a lightweight crank.
The Magnum XL weighs 44 lbs instead of the regular 51-52 lbs.We're using one in my turbo engine.
