ANOTHER head and cam question
I am looking for the BEST h/c combo. The block is a 2000 ls1 with all lower internals stock. Will be mated to a th400, in a 3000lb vehicle. I want the BIGEST cam that can be used with the stock pistons without cutting. Emissions are not a problem, the motor will be in an offroad application. The rpm should be somewhere between 1500-6000. I want a heavy/rough, lots of lobe idle. Now I need heads to flow good with a suggested cam. I need to keep about 10.5:1 on the compression (pump gas).
Can someone please suggest the best h/c combo with all the specs listed. I will need to know int/exh, lift and lsa of the cam. I want to know the head cc, valve sizes, what springs and retainers.
Thank you, Joey
Thank you, Joey
LS1Tech Premium Sponsor
Joey we have a package we've put together using Precision Race Components Stage 2.5 heads & a Mini Stick Camshaft. This combo has gone near 460rwhp in the dyno section of the site. The 5.3l heads should put you a little bit over 10.5:1 compression, but it should work really well on pump gas & peak by about 6300 or so
The Camshaft Is A:
TSP 235/240 .603/.609 113 Comp Aggressive Lobe Camshaft
PRC Stage 2.5 heads
*Brand New GM 5.3l Castings
*Manley 2.04/1.575 Valves
*PRC Gold Double Spring Kit
*Titanium Retainers
*Seats, Seals
*Fully CNC Ported
*Fully Assembled & Ready To Install
Texas Speed 7.400" Hardened Pushrods
The entire package for $1999.99!!!
The Camshaft Is A:
PRC Stage 2.5 heads
*Titanium Retainers
*Seats, Seals
*Fully CNC Ported
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
__________________
Jason
2005 Twin Turbo C6
Jason
2005 Twin Turbo C6
Jason, Thanks for the reply, that is the answer I was looking for. That sounds like a good combo to me. I won't have any valve/piston clearence issues? Does that cam have a wide power band? How long does the combo take to get from time of order?
Thank you, Joey
Thank you, Joey
If the TSP package doesnt fit your needs I have a set of MTI LS6 stage 2e's and a X1 cam (230/227/112). PM me and I'll give you a great price. The heads a TWO mths old and the cam has 4500K on it. This combo made 448rwhp on an 01 Z06 w/ normal bolt ons. Good luck in your choices as there are many out there.
Originally Posted by J.N.F.
not trying to hijack your thread here.............
PM sent
Man that car is only 3000#??
__________________
Jason
2005 Twin Turbo C6
Jason
2005 Twin Turbo C6
I dont know if this would help. But maybe you should look into Rapid's dominator package. 500hp at the wheel. I have seen a camaro with this package on and boy is it nasty.
The Camshaft Is A:
PRC Stage 2.5 heads
*Titanium Retainers
*Seats, Seals
*Fully CNC Ported
The Camshaft Is A:
PRC Stage 2.5 heads
*Titanium Retainers
*Seats, Seals
*Fully CNC Ported
Honestly this is one of the nicest packages I have ever seen for under 2500 bucks. You get compression, a large cam with nice specs and everything needed for the install for 2 grand is awsome.
I know you said it was a off road applaciation, and therefore I will also suggest a larger torque converter if your staying NA.
You wont find a better package for 2,000 then the one above period, but at the same time dont expect much more then 410HP.
460 I can see through the M6, but you will have a large loss of power through the A3, big verter, 12 bolt etc. You will at the same time however run a faster time.
If you have a budget to spend it would help us provide other choices as well.
Where would find this info??
410hp???
I am open to all options with a budget up to $2500. I just want good hp and torque, what do I need?? Thanks for all the replies. Joey
Check their website on the right----------------------------> 199-pkg3 comes with prc 2.5s,cam of choice(mini stick),ported oil pump,bolt and gasket kit,pushrods and double roller timing set I was qouted 2350 for this on wednesday
Its under engine and valvetrain tsp heads &cam packages-precision race components- it doesn't have a price listed towards the bottom of the pagehttp://www.texas-speed.com/item_detail.asp?ProductID=802
