Lower End Knock
Old 03-25-2005, 10:46 AM
pphilli1's Avatar
Default Lower End Knock
Developed A Lower End Knock At 1700 Rpms.very Faint But Heavy Under Load.seems To Smooth Out A Little Past 2200 But Comes Back After 2500 Rpm.had A Lifter Go Bad & Wipe A Cam Lobe-i Flushed The
Motor 4 Times ,no Signs Of Metal In The Pan,i Also Replaced The Oil Pump.this Sounds Like Lower End Rod Knock.i 've Never Heard Piston Slap Like This.this Started After About 2,200 Miles On A Reman Short Block.any Help?
Old 03-25-2005, 03:36 PM
technical's Avatar
Did you get a warranty with that reman?
Piston slap will go away after the engine runs for a minute. Sounds like that lifter/cam incident got to a bearing.
Old 03-25-2005, 04:15 PM
tonydss's Avatar
dude i have the same exact problem!!!! what kind of air intake do you have??????? maybe rods are bent well when you find out tell me please!! i chaged my knock sensors wasnt that!! and clutch
i have the volant intake
Old 03-26-2005, 10:14 AM
pphilli1's Avatar
Just Spoke To The Vette Expert At Our Chevy Store Yesterday.he Heard The
Sound & Said That One Of The Rods Has Excessive Clearance,more Than Likely A Bi-product Of The Reman Process.the Sound Has Gotten Worse Since The Post Yesterday So The Vehicle Is Not Being Driven At This Point.fortunatley The Reman Warr Covers A New Short Block.
Hopefully This One Will Have The Correct Tolerances.this Noise Developed In Less Than 2,400 Miles.
