View Poll Results: 5w30 or 10w30 for racing in a stock LS1
5w30
51.22%
10w30
48.78%
Voters: 41. You may not vote on this poll
5w30 or 10w30
Old 03-26-2005, 02:53 PM
Bad N Black's Avatar
Default 5w30 or 10w30
HELP, what oil sould you use in a SL1 for racing. What is the best weight between 5w30 and 10w30 THANKS.
Old 03-26-2005, 11:00 PM
glennhl's Avatar
Neither: 0W-40.
Old 03-26-2005, 11:03 PM
kukri's Avatar
i used 0w 50
Old 03-27-2005, 12:26 AM
grt68goat's Avatar
It isn't so much of a weight thing as it is what the material properties are of the brand you want to use. 5-30 is lighter than 10-30, yes, but depending on brands you can see trade offs between power and wear. I would run a Torco 5-30 if it was my car (worth a couple HP @ the wheels over a Mobil 5-30). Mobil wears a little better than Torco though. Just my 2 cents.
Old 03-27-2005, 02:18 AM
denton needham's Avatar
depends on if you have a stock motor or one built, My builder set up my motor loose and likes a 20-50 mobile 1. Mobile doesn't make it any more but has a 15-50 which is what I use now.
Old 03-27-2005, 08:23 AM
LS1TECH Sponsor
Steve Burger's Avatar
Another vote for 0 - 40
Old 03-27-2005, 08:35 AM
11 & 7 Second Clubs
Race Car Driver's Avatar
There are a couple of recent threads that have debated this question extensively. In general, engines with lighter oils will make more power than heavier oils, but engine wear may be greater with lighter oils. Ultimately, you have to decide which is more important to you.
Old 03-27-2005, 09:52 AM
Default That is good info
THANKS
Old 03-27-2005, 03:22 PM
Tom@SpeedInc's Avatar
0W30 German Castrol. The only differance between 0 weight 5 or 10 is cSt (viscosity) during cold start. What is a 30 weight oil is different for all oil companys, for Mobil 1 5 or 10W30 is 10cSt but German Castrol is 12.2cSt, by far its thicker then M1 5W30.
Old 03-27-2005, 06:34 PM
gollum's Avatar
Not only will lighter oil help lesson drag on the internals, less oil in pan helps also. Some drag racers fill their pans with less oil "below" the add mark on dip stick for more horsepower.
Old 03-27-2005, 09:43 PM
Wanna run light oil, just run mobil 1. Unless its 0W40 that stuff is thick. NHRA pro stock cars run 0 weight oil or something similar to a 0W5 oil if was SAE rated. Top fuel cars run 70 weight oil.
Old 03-27-2005, 11:28 PM
RIP April 14, 2008
Diolar Magnum's Avatar
Location: the land where cars repeatedly hit my bumper when I'm in the store...
syntec 0w40 (thanks patman!)
Old 03-28-2005, 03:54 PM
01_SuperSlow's Avatar
Originally Posted by glennhl
Neither: 0W-40.
Quick Reply: 5w30 or 10w30
