Low mileage 409 piston skirt damage
Old 03-26-2005, 09:38 PM
Blown Yellow's Avatar
Default Low mileage 409 piston skirt damage
Hello,
I have a lunati 409 in my 2001 silverado and had to tear it down after 12,000 miles because of what sounded like a rod bearing. Once I got the pistons out I found that the number five piston skirt was extremely worn and grooved, aswell as the bore. The ring lands and top of the piston are as they should be and now I am racking my brain trying to figure out what went wrong.
I have yet to mic the bore to make sure that the builder did it to spec but was curious if anyone has any suggestions as to the cause?
Thanks,
Martin
Old 03-26-2005, 11:29 PM
GueSS Who's Avatar
What is your bore and stroke on that one.
Old 03-27-2005, 12:46 AM
12 Second Truck Club
Magic Chicken's Avatar
408 is 4" stroke 4.030" bore
Old 03-27-2005, 04:04 AM
BOWTIE's Avatar
Could be any number of things... debris in the cylinder, if it has moly rings a piece of it could have broken off, could have a burr at the bottom of the cylinder both wiping oil off the skirt and scraping the skirt, bore could have been set up too tight, motor could have been run too hot, there are a ton of things that could have caused it. Hopefully you get it figured out and fixed.
Old 03-27-2005, 01:40 PM
Green Thunder's Avatar
Originally Posted by Blown Yellow
Hello,
Thanks,
Martin
Any chance of posting a pic?
Old 03-27-2005, 08:26 PM
I will get a picture posted on Monday, I was starting to lean towards the cause being debris but I can't find any broken rings or anything obvious. I will grab a good mic set from my pops shop and check for bore taper and size on Monday as well.
Old 03-27-2005, 09:48 PM
Cool, look forward to seeing the pics!
Old 03-28-2005, 06:01 AM
racer7088's Avatar
Thumbs up
Could be deris from the valvetrain since after initial startup as you will have a lot of this wearing off in the first few miles. What's important is what is up in the tops of the cylinders. Also the bottom of the bores need to be chamfered after honing but few shops do this. You're probably fine.
On an all out race engine sometimes we will deburr and chamfer every single spring and this cuts down on these debris a lot but it is incredibly labor intensive. This would be on say a NASCAR or 25K and up kind of engine where you are getting payed to do this sort of thing. No one works for free and you can easily put 20 hours of just prep like this into some of these deals.
Of course without seeing it there is no real way to tell as the next biggest cause of this is simply dirty engine assembly. You'd have to see if the bearings are also also all scored up. If they are then you might have a case of probably an engine not put together too clean but if they are perfect it's probably more like what I wrote about above.
Old 03-28-2005, 07:19 PM
BOWTIE's Avatar
[QUOTE=racer7088]Could be deris from the valvetrain since after initial startup as you will have a lot of this wearing off in the first few miles. What's important is what is up in the tops of the cylinders. Also the bottom of the bores need to be chamfered after honing but few shops do this. You're probably fine.
I used to chamfer them after the bore job but before the hone... and I always like to finish the cylinders with a brush as well, which would remove or roll over anything that might have been left after the hone.
