I thought AFR were the only ones with a new LSX head(guess not)
SSU'S Vice Mod
Originally Posted by 66deuce
don't forget about the edlebrock ls1 head.it's not out yet,but the more companys that make heads will eventually bring the prices down somewhat.(i hope,lol).
If we could just convince Pro Topline (formerly pro action), DART, Brodix, and Trick flow to do it too...then we'd really see some price drops!!!
SSU'S Vice Mod
no kidding!just think back to when the SBC first came out.it took what,15,20 years or so before the aftermarket kicked in and came up with some more options.hell,the ls1 hasn't even been around for 10 years yet.
And there are two aftermarket heads on the maket, a third on the way, and tons of companies CNC machining and milling the factory castings. It's good to see the All Pros are offered with more deck though. I'm sure we'll see revised valve angles, splayed vavles, and really insane stuff in the next 5~6 years. Time is key. Can you think what will happen though if World starts to offer aftermarket tall deck blocks, or even one with a revised 5 head bolt per cylinder pattern?
Could you imagin if checy would continue to build the F body to give aftermarket companies a better reason to make new products?
Hopefully the Vette and GTO owners mod enough to help us out. Good thing the LS1 and LS2 are so similar.
i want to see some heads that are gunna be WICKED. So far the AFR's have been impressive but I want to see some heads that are gunna help break the 8 second naturally aspirated barrier). Thats the kinda heads I want!
Josh S.
Josh S.
Originally Posted by 8KickassRS9
maybe even a gen 3 style head for a gen 1 sbc. this jus confirms my thoughts, its the 50's all over again in terms of hot rodding.
SSU Moderator
search...specifically for "All Pro" or "All Pro Heads"...or for threads started by "427" They are cheap as-cast heads that flow 290-300cfm with a fairly large cc runner. They are more for a nice base for a all-out ported head. There is enough material for 300cc runners. They come in 65cc and a dual quench 55ish cc chambers. Thick deck...nice aluminum casting.
I want some.
I want some.
