will this radical cam fit stock heads?
i bought a cam last summer with these specs
236/242 .601/.610 112 +4, IVO = 10, IVC = 46, EVO = 57, EVC = 5, (@.50)
i have a 97 C5 coupe now, and i was looking through the broom closet and found this thing just laying around needing a good car to go into ... i got some info last summer that would suggest that it will NOT fit with stock pistons. is there any way to find out FOR SURE without removing the heads, weather or not this cam will fit???
thanx
mike
thanx
mike
Originally Posted by 01-Z
Looks like it should fit. The TREX is alot bigger on a 110 LSA and it fits.
thanks for the info guys... what would make the people that i talked to last summer ( people on the board) suggest to me that it would NOT fit... any info will be GREATLY appreciated!
edit... it has +4 ground into the cam. i could just put it in straight up with an adjustable timing set right? and where is a good place to get an adjustable chain at???
thanx guys!
mike
thanx guys!
mike
Originally Posted by taufern
install it and then measure. then you'll know for sure.
Nate
Nate
mike
