AFR 225 72cc: compression???
Old 03-31-2005, 02:29 PM
RW99's Avatar
Question AFR 225 72cc: compression???
What will my compression be with these heads, a cometic gasket, and a stock bottom end?
Thanks,
Rich
Old 03-31-2005, 02:37 PM
SDB
SDB's Avatar
get the 205's for stock bottom end UNLESS you are running a HUGE cam, FAST 90mm intake, 90mm TB, a lot of rear gear, etc....
Contact Tony Mamo at AFR for actual specs, it is the best route...
Old 03-31-2005, 02:58 PM
RW99's Avatar
I'm going D1SC on the car, and yeah, maybe I'll blow it up. We'll find out.
Old 03-31-2005, 05:36 PM
RW99's Avatar
Paging Tony?
