Cam or converter?
Old 03-31-2005, 04:50 PM
nikon1999's Avatar
Default Cam or converter?
I've got a nice cam sitting on my desk that i can put in, or i can get a converter and put it in, but can't afford both. I'd like the cam in cause it'd sound cool and add a good amount of power but with stock converter that'll probably melt down pretty quick and down low it'll suck. With a converter it'd be a nice gain but then i'd have this nice big cam sitting at my desk looking at me for another couple months? what to do
Old 03-31-2005, 05:09 PM
Crazy Man's Avatar
Converter for shure here....
ls1_doc's Avatar
I have not done a cam yet but so far the converter has been the best mod i have done. What size?
Old 03-31-2005, 05:11 PM
Moderator
davered00ss's Avatar
On an A4, always do the converter before a cam.
Old 03-31-2005, 06:18 PM
Casperws6's Avatar
i did cam first and haven't got a converter yet. i'm happy so far
Old 03-31-2005, 06:20 PM
JBGRAYTA's Avatar
Get the freakin' converter!!! Cam b4 converter, wtf??
Old 03-31-2005, 06:22 PM
Casperws6's Avatar
different strokes for different folks
Old 03-31-2005, 06:53 PM
nikon1999's Avatar
white how is your stock converter handling the power? whats driveability like down low? whats your numbers if u dont mind?
Old 03-31-2005, 06:56 PM
Casperws6's Avatar
it takes off pretty hard off the line for having a stock converter. i dyno 360/360 SAE corrected, cam only w/ ls1 intake.
Old 03-31-2005, 07:13 PM
GM Muscle's Avatar
Deffintaly do the converter first. You should gain more, and if your going with a good size cam it will probrably suck with the stock stall.
Old 03-31-2005, 07:23 PM
nikon1999's Avatar
alright well the converter will be cheaper anyways.. The question now is which one? I'm thinking Yank ss3600? Right now i'll just be running drag radials on stock rear. I know im asking for a lot but looking for a converter that will be good now and with the cam, but also be fairly decent on street and good at track. Thanks guys! the input is great
Old 03-31-2005, 07:40 PM
Torqued's Avatar
Just to reiterate install a converter first! I was tempted by the top end power gains of a cam install, but a converter makes so much more sense for a daily driven car. My only regret of installing the Yank converter is that I did it at 90K miles rather than 1K miles. Also don't install a converter smaller than 3500, get a cooler, and reprogram your PCM.
Old 03-31-2005, 07:50 PM
2MuchRiceMakesMeSick's Avatar
I would go with a converter first. Both make a big difference but the converter will make a big cam(if you go big) easier to drive.
What size converter depends on your goals for the car.
What size cam are you gonna run?
Old 03-31-2005, 08:22 PM
smask04C5's Avatar
go with converter first in an f body, my car is not a DD, cam works well with stock converter. will be next mod with another set of heads
Old 03-31-2005, 09:20 PM
Mac 2002 SS's Avatar
Another vote for the converter install first . Once it is in, you will have the biggest smile on your face and you can't wait to cut someone nutz out at your local track . I see you have already ran a 12.8 . If you install a 3200 or more converter in your car, 12.3's or better are yours.........easy ! Good luck
Old 03-31-2005, 09:48 PM
nikon1999's Avatar
its a baby cam just a little over .600 lift.
The car gets driven to car shows and cruise it all the time, occasionally im sitting in heavy traffic at the beach or something so i dont want to have to worry about over heating issues w/the tranny. I try to avoid the situations but sometimes you just cant help it. No opinions on the SS3600 yank?
Old 04-01-2005, 03:01 AM
Nocturnal SS's Avatar
Converter! I took off a half second with just the converter 3200 stall.
Old 04-01-2005, 03:17 AM
TNormZ28's Avatar
If you get a TCI SSF 3500 then you can do both the cam and converter for the money you saved not getting the Yank, but the ss3600 is a damn good verter. I was driving a 3200 daily but just stepped up to a 4400 and like it way better than the 3200. Daily driving is fine, but I've got 3.73's so it's a little tighter than a stock geared car.
Old 04-01-2005, 03:27 AM
MNR-0's Avatar
What cam spec. is it?
Old 04-01-2005, 06:33 AM
7 Second Club
ty_ty13's Avatar
yank ss4000e here... love it!
dropped 60ft. by .3...
cuttin 1.58 on stock rims and DR's
day light under front left tire makes me smile
