Patriot Gold Springs
Old 04-02-2005, 01:57 AM
98cobrakillata's Avatar
Default Patriot Gold Springs
Patriot Gold Springs how many miles are they good for on say no more than .600 lift?
Old 04-02-2005, 02:10 AM
luv2spd's Avatar
Depends a lot on usage, how often it sees high revs, proper break-in, etc. In general I'd say a good 15-20k.
Old 04-02-2005, 02:18 AM
well these would be on a daily driver.so they would see all rpms regulary.
Old 04-02-2005, 08:29 AM
Bad30th's Avatar
An educated guess would be 15-20k to be safe. Depends on many things - including cam lobes/lift, operating conditions and break-in.
It's kinda like asking "if I eat right how long will I live". The time could come tomorrow, or it could (hopefully) be a long time.
The double springs should give you a little more peace of mind knowing that the valve shouldn't drop even if one spring does break.
Cheers,
Bad30th
Old 04-02-2005, 09:26 AM
cyphur's Avatar
20-25k unless you take it to the redline every day, on a decent sized cam.
Old 04-02-2005, 09:59 AM
Lostpatrolman's Avatar
do these springs need to be shimmed ?
Old 04-02-2005, 12:51 PM
ROCNDAV's Avatar
So, if a person was to install the PP springs, would it be a good idea to rent or purchase a spring tension measuring tool? then compare tension at 20-25K?
If so, how much change should be allowed, or should they just be changed?
David
Old 04-02-2005, 01:41 PM
luv2spd's Avatar
No they do not.
