Picked up 35 rwhp w/the T-ReX over the C2 cam!
Highest dyno on the C2 cam was 363 rwhp, highest dyno on the T-ReX 398. Only changes that were made was, cam of course, Patriot Gold dual spring kit, Rollmaster double roller timing chain set, Thunder Racing ported & blue printed oil pump, Katech rod bolts, and SVO 30 lb. injectors. I'm pretty impressed. From the stock cam to the C2 I picked up 52 rwhp. Man...what cams can do for these cars. Now its time to step up to a 90mm intake and throttle body.
By the way, this is on stock heads, LS6 intake, through a fully built 200-R4, Yank PT4400, Strange 12 bolt w/4.10 gear, slicks, and unlocked.
what heads do you have?....853s or 241s the 241s seem to be worth 5 or maybe a lil more over the older 853 heads.....either way awesome numbers for stock headed car with that drivetrain unlocked....now go bust rodneys *** haha and run a 10.3x
erodrig2, I dont have a/c anymore, so I cant speak for it. Before the tune, it was hard for it to catch idle, but its not so bad now. I have a loose converter and a 4.10 gear, so its not too bad. I dont drive it on the street much anyway. Every one has their own opinion as to whats loose though. If you plan on keeping this a daily driver, its not something I would really recommend because its gonna kill your gas mileage.
P Mack, I can take a pic of it here in a minute and post it.
Thanks everyone for the compliments.
